Fuel Moto / Jackpot Mufflers USA's leader in EFI tuning and exhaust systems.
Map question
Old Apr 15, 2010 | 04:34 PM
ejohnson1's Avatar
ejohnson1
Default Map question
Hey guys, Bike (2010 Softail) was stock until I added from you: V&H Straight Shot full exhaust, PCV & Fuel Moto air cleaner. I just changed the pipes to use Big City Thunder's original baffles and was wondering if the map you sent me is still optimal, or should it change with the different baffles?
Also, does it make a difference in mapping if I run the A/C open or covered?
I am getting a good amount of oil blow out from the air cleaner, I know there are countless threads on this issue, but thought I would ask about your A/C specifically, do you have any tips to minimize or eliminate this?
Thanks for the help!
Old Apr 16, 2010 | 11:54 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Hello, we do all of our maps with the baffles in place however the map we provided should work well with the Big City baffles. If it needs any fine tuning we would be happy to revise your map for you. The air cleaner cover will not affect the map. If you are getting some oil in the AC it is generally from running the oil level on the high side. I recommend draining some oil so it reads in the lower area of the dipstick.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
rockstarbass1
Nov 9, 2013 11:06 AM
Allen Riggs
Jul 29, 2013 12:02 PM
dtone72rss
Apr 26, 2012 04:10 PM
coachstorms
Jul 26, 2010 11:25 AM
Kdavid
Apr 9, 2010 09:25 AM
