FXR Models Discuss the FXR Models in here
Ignition module
Old May 25, 2024 | 10:32 PM
BrianH's Avatar
BrianH
Default Ignition module
Ok, I just replaced my nose cone timing sender (92 FXLR) with a Ultima single fire programable kit. read the directions, Wires are red,blue,white green violet Blue to front pin, red to the back pin, and white to the center. Green and violet taped off. (No VOES,or Tach)I removed the module under the rightside cover and i'm wondering if theres something in THAT module that im missing. It doesnt seem to be charging. I'm stumped, HELP!!!
Old Jun 9, 2024 | 06:19 PM
Redrodyankneck's Avatar
Redrodyankneck
So you replaced a single fire with a single fire?
Old Jun 9, 2024 | 10:48 PM
BrianH's Avatar
BrianH
I replaced a 25 yr old Dyna 2000 module with an Ultima programable nose cone unit. in the mean time i changed out my rectifier and problem solved!!
Old Jun 10, 2024 | 09:19 AM
Joe12RK's Avatar
Joe12RK
You did the right thing, the ignition module has nothing to do with charging, but you will like it. I suggest installing VOES, it will allow a better advance curve.
RohsHeck
26
Dec 5, 2023 11:15 AM
Kennys_world
Jan 10, 2022 03:24 PM
CaptainHook
Jun 1, 2013 07:56 AM
Chopper-d
Jun 1, 2012 01:22 PM
joebra
Custom Models
Feb 4, 2011 12:59 AM
