Problem Diagnosing Electrical Issue
Old Oct 8, 2014 | 05:57 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Unplug the connector for the right side handlebar switches, clip your test light to the positive battery post, probe the terminals that go to the switches, if the light comes on you have found a short to ground.
The issue could also be in the wire that runs between the connector and the ignition coil.
With the connector still unplugged, remove the wire from the coil and do the same test light check (on that wire). If the light comes on, the short is in that wire.
Old Oct 8, 2014 | 07:23 PM
Ragtop's Avatar
Ragtop
Originally Posted by no pckl
with the plug to the hand grip disconnected, the wires should be all isolated (nothing to power or ground). Take an ohm meter and check for a short between each wire in the plug and ground (the frame). Don't forget to check each wire with each switch in both positions (remember they loop through the switch) to figure out which side of switch the wire is bad on. Might have to wiggle the wire around to fine the short, but shouldn't be too difficult to find.
good advise!
Old Oct 8, 2014 | 07:32 PM
Michael knowles's Avatar
Michael knowles
Current draw causes breaker failure. That's why the rating of 15 amps. Constant resetting will weaken the by metal strip. If you can measure the current draw it will tell you why the breaker tripped. Above 12 amps is the upper threshold & should trip.
Old Oct 9, 2014 | 09:12 AM
FatboysFatboy's Avatar
FatboysFatboy
Default Wow got me confused
Got to troubleshoot one thing at a time. Got right bar control isolated but then moved to ignition switch and then coil. Hold on a little. I would put right bar control back on and connect with ignition switch disconnected and coil disconnected. Does it work? Then add ignition switch with coil disconnected. You can use any order you want but disconnect one thing at a time. Eliminate that and then restore all and move to the next item. Unlikely you have had two items fail at the same time. If you can get it running check voltage out of regulator. 13.5 to 14. I still think it's in the bar control but could be a shorted coil primary. You'll get it just takes time to test each item and then stop and think about it. Been there and it's not fun.
Old Oct 11, 2014 | 01:09 PM
Damien Bessent's Avatar
Damien Bessent
Exclamation *update*
I have reconnected everything as it was, and completely removed the voltage regulator (since I can't get the bike running to test the current on it) and reapplied power to the bike. With the voltage regulator disconnected and everything else exactly as it was, the circuit breaker does not trip. Does that mean my VR is bad? Or does it complete another circuit to additional components that could be tripping the 15A accessory circuit breaker? It only has three wires coming out of it. One is the hot lead, and the other two are connected to male bullets that plug into the Evo motor near the oil filter. I'm pretty sure that runs to my stator and charges my system, right?
I also wanted to reconnect the VR and see if it would still trip the circuit, but like an idiot I didn't mark or remember where I pulled the hot wire to the VR from. lol Does any body know where I pulled it from? Sorry, that was a completely moronic move. I marked every wire before, but I got ahead of myself for some reason this time.
Old Oct 11, 2014 | 04:12 PM
Dan89FLSTC's Avatar
Dan89FLSTC
We don`t know how your bike is wired, it is a custom....
The Motor Company wires the regulator in between the battery and the ignition switch, sometimes before the main breaker, sometimes after the main breaker, depending on the model year of the bike.
If your voltage regulator was causing the accessory breaker to trip, it would have to be wired in on the output side of the accessory breaker, which would be weird...
Tip: take pics of stuff before you disassemble....digital film is really cheap these days.
Old Oct 12, 2014 | 07:41 AM
Damien Bessent
That, sir, is pure genius. lol I was listening to music on my iPhone the entire time, and it never occurred to me to take pics. But I think I figured out where the voltage regulator went. It's hooked up to the 50A main breaker, not on the copper terminal. Does that sound right?
I also believe I've found my electrical problem. I started exposing everything again to follow the "diagnose one component at a time" advice, and found a melted wire at my Dynatek 2000i digital ignition. If it's not my problem, whatever is my problem has cooked it I think. But could that trip the accessory breaker? Or is it just a victim?
Old Oct 12, 2014 | 09:06 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Yes
First determine if the ignition system is connected to the accessory breaker, this would not be common, normally there is a breaker specifically for the ignition system.
If the ignition is not connected to the accessory breaker, don`t go barking up that tree now, it is not the issue (yet).
Let us know what breaker the ignition is connected to.
Old Oct 12, 2014 | 12:41 PM
Damien Bessent
There are 5 wires coming out of the 2Ki under the camshaft cover- pink, white, green, blue, and purple. Green, blue and purple are capped and run to nothing, but white and pink are connected to the coil. The white shares a terminal with a gray wire. That gray wire runs all the way up to my kill switch in the "OFF" position, and the "RUN" position of the kill switch is a white w/black stripe wire. That wire runs into an identical wire coming off of the start button, and they become one white w/black stripe wire that runs to the 6-pinned plug. There it connects to a lower gauge (18 to 16 I believe) white wire with a thicker black stripe, and that runs into my frame with the rest of the wiring harness.
Confused yet? lol
Inside the frame, that 16 ga white wire with a thick black stripe gets connected to a 14 ga orange wire along with a blue wire, an orange wire, and an orange w/white stripe wire. There are 2 other orange wires of the same gauge that connect to my ignition switch. When those 3 orange wires come out of the frame under the seat, 2 run to the accessory breaker and 1 runs to the main breaker.
I can keep pulling and following wires if I need to, just let me know which ones I need to chase.
I think it's also noteworthy that there is a circuit board connected to the wiring harness that only seems to connect to brake lights, turn signals and my headlight. It also has a ground wire but it also has a blue wire that isn't running to anything. It's a clean cut with no evidence of tape or heat shrink around it, so I think it got cut by the mechanic who started chasing this before I told him to stop four hours into a diagnosis. $85/hr was killing me and he still had no idea what the problem was, so I figured I couldn't do any worse. lol
Old Oct 12, 2014 | 01:30 PM
Dan89FLSTC's Avatar
Dan89FLSTC
You still haven`t told us if you checked for a short to ground in the handlebar control wiring.
Use an ohmmeter and follow the suggestion in post #5, or use a test light as I suggested in post #11.
Here is how an OEM handlebar control switch is wired:
The gray wire is the power supply for the ignition, it runs from the ignition breaker, through the connector at the handlebar then into the kill switch.
When the kill switch is set to run, the power comes out of the switch via the white/black wire.
The white/black wire has a leg that runs to the start switch.*
The white/black wire then runs to the connector, after the connector it runs to the ignition coil and then the ignition module.
*The wire coming out of the start switch is black/red, it runs from the start switch to the starter relay.
