What do these dash lights mean?.,,
Old Dec 28, 2014 | 05:44 PM
dyna rider's Avatar
dyna rider
Default Battery Light
About 7 years ago, when I first started using a tender, I would get a red battery light when I first started the bike. It only lasts for a few seconds and then will go off. It still happens to his day and the stator is charging 14.7 volts. New batteries haven't changed the process so I just ignore it and ride on.
Don't fix it till it is broken...
Old Dec 28, 2014 | 06:01 PM
HDmikie's Avatar
HDmikie
I had the same thing happen. My indie told me to disconnect the battery for a couple minutes and reconnect it. Problem solved. IIRC, disconnecting the battery will reboot the ECM.
Old Dec 29, 2014 | 11:31 PM
lh4x4's Avatar
lh4x4
Air cooled engines respond to the cold dense air with more power. Unless you have taken the Harley out in the teens to twenties temperature you will never experience the full power of the motor. It is awesome.
In the winter my 96's and 103's think that they are 120R's!
sanman4ever
Mar 10, 2016 04:40 PM
Timmy B
May 22, 2014 10:19 AM
2ropes
Mar 31, 2014 06:10 AM
sgl0226
Jul 14, 2013 09:03 AM
883 IRON
Aug 10, 2009 12:57 AM
