Loose riser
Old Jan 17, 2015 | 08:26 AM
decencyxdefied's Avatar
decencyxdefied
I have poly bushings and there is still some flex but very little.. I know my bars are torqued to the right specs as well.. You have to expect some movement with taller bars...bushing are easy to install.. Take it apart and add new ones and be done with it.
Old Jan 17, 2015 | 08:30 AM
Greezey Rider's Avatar
Greezey Rider
Originally Posted by Knucky
Remove top riser plate, smear red loctite around the bars where they contact the risers, re-install top riser plate. Let sit overnight. Your bars will never move again.
How will that tighten up the bushings?
To the O/P...Just take the old rubber bushings out and put in a set of poly bushings, it'll solve the problem and it only takes a few minutes.
Old Jan 18, 2015 | 08:51 AM
sporty63's Avatar
sporty63
Thanks for the suggestion, however it's not the bars that move. It's the riser and speedo that have a little play.
Old Jan 18, 2015 | 09:05 AM
DannyZ71's Avatar
DannyZ71
Originally Posted by 2500hdon37s
rubber bushings + bars that have more leverage= you see/ feel / can make more movement.
This ^^!
Old Jan 19, 2015 | 08:09 PM
sporty63's Avatar
sporty63
Poly bushings set, much better!!! Thanks for the help all!
Old Jan 20, 2015 | 05:10 PM
High Roller's Avatar
High Roller
May I suggest you look for another shop next time. If they didn't know better than to reuse the rubber bushings, they are lacking in basic knowledge. You paid them to do the job correctly didn't you? Even if you didn't ask them to use poly bushings, they should have recommended it to you before completing the work.
Old Jan 20, 2015 | 05:23 PM
sporty63's Avatar
sporty63
High roller....my thoughts exactly!! Not only did they not recommend this, they gave me the bike back with burnt out front blinkers, a nut and bolt missing from the bracket that holds the clutch cable to the frame. That's careless work in my book.
Old Jan 21, 2015 | 08:13 PM
Pete3323's Avatar
Pete3323
God I hate this! Shops charge obscene $ and do this kind of work. Awful.
94-Sporty
Feb 24, 2013 09:35 AM
cf7go
Apr 20, 2012 07:28 AM
Voony
Sep 6, 2011 01:17 AM
Voony
Aug 22, 2011 06:33 AM
DR. V-TWIN
May 8, 2010 08:18 AM
