help... no brakes
Old Mar 20, 2015 | 09:49 PM
jtarter's Avatar
jtarter
If you put the spacers on the wrong sides and had the caliper on the rotors and then tightened everything up, you most definitely bent the rotors. Not sure what bike you are working on, but on my Deluxe, rotor side has a 1" spacer and the other side is about 1/2".
Old Mar 20, 2015 | 10:39 PM
dav500's Avatar
dav500
Originally Posted by Harleycruiser
Well that is because the bent rotors push the pads back into the calipers, and it takes a pump or two to push them back out.
Did he pull the rotors off when he changed the tire?
This sounds close.
My guess is the rotor wasn't removed during the tire change, and it got leaned on by a tire spoon, and bent it.
Mark the high or low spot with a piece of tape. Then give it a lite tap with a piece of wood. You may have to do it in a couple different places to get it right. Just go easy with the hits, it don't take much.
When your persuading the rotor, align it with the stationary pad.
I trued mine with a 12" long piece of wood from the backside of the rotor. Then lite taps with a lite hammer on the wood.
Just tap it, spin it and repeat till its straight.
A couple clunks in the right spot all fixed.
If your uncomfortable just replace the rotors.
Old Mar 20, 2015 | 10:47 PM
jtarter's Avatar
jtarter
I would say replacing the rotors are a cheap alternative to not having any brakes when you need them!
Old Mar 21, 2015 | 12:20 AM
Iarecobra's Avatar
Iarecobra
Without moving the bike. Pump up the brake and hold. If the lever slowly goes in while your not moving then the master cylinder seals ruptured and the master cylinder needs to be rebuilt.
Old Mar 21, 2015 | 09:22 AM
JW1200's Avatar
JW1200
Or, there is air in the caliper.
Old Mar 21, 2015 | 09:26 AM
Hippie49's Avatar
Hippie49
I'm with the air in the lines or defective master cylinder.
Old Mar 21, 2015 | 12:10 PM
YeOldeStonecat's Avatar
YeOldeStonecat
I'm going with air in the line, or ruptured seal, master cylinder. I don't see how you could have put the calipers on if the rotor was not mounted correctly...with spacers on wrong side. You'd not be able to put the caliper on. Bent rotor...certainly easy enough to eyeball but that wouldn't cause the level to slowly sink in. Lever sinking in slowly means leak somewhere.
Old Mar 21, 2015 | 01:48 PM
Harleycruiser's Avatar
Harleycruiser
OK guys one more time, op has good peddle until he moves it, he can see he has warped rotors.
Warped rotors push the pads out, that pushes the pistons into the calipers, that pushes the fluid back Into the master cylinder.
That is why you have to pump the brakes twice, first time just brings the pad up to the shoe second time pushes the pad onto the rotor.
If the warped rotors are turning then when you go to pump it again the warped rotors push it back in so no brake.
Until you stop.then op has good petal until he moves the bike.
No amount of bleeding the brakes, rebuilding the master will cure this problem the warped rotors is causing.
Old Mar 22, 2015 | 08:55 AM
nitros's Avatar
nitros
Exactly,, So we replaced the brake rotors.. Verified the placement of the spacers and all is good now.. I just wish I know what happened to warp the rotors.. o well she is fixed and ready to ride.
Thanks for all the help guys.
Old Mar 22, 2015 | 11:09 AM
Harleycruiser
Would the tire spin when it was on backward, and did you read my second post?
kpb46
2014-2024 Touring Models
May 28, 2015 09:06 AM
FL-kruzen
Nov 10, 2013 11:32 AM
TracerBullet
Wheels/Tires
Oct 31, 2013 12:40 PM
TexasJR
Detailing
Jun 8, 2012 07:38 AM
jokr
Feb 6, 2008 05:08 PM
