Dyna/Sportster center of gravity
I bought the aforementioned 5x8 trailer, decked it with 3/4 treated plywood, installed 2 locking wheel chocks for the Dyna and Sportster. I added 2 large eye bolts in the front center for cargo straps and 2 small d-rings in the rear (because they will lie flat on the floor for loading).
I got the centers of gravity pretty much spot on. With both bikes loaded, the tail lights sit about 2 inches from the ramp (in travel position). With both bikes loaded, the tongue weight is such that I can easily lift the front of the trailer by hand, and yet there is enough tongue weight that it rides securely.
After letting the wood fully cure, I applied 3 coats of roll on truck bed liner coating.
Here's a pic.
Ride Safe - Ride Smart
"He Who Lives In Joy Does His Creator's Will".
The Baal Shem Tov, Founder of Chasidic Judaism... ca. 1750's
I have set up many trailers for towing bikes over the years. the standard is 10% of the gross weight on the hitch. Single axle 60% of the load in front of the axle. Dual axle 70% ahead of the axle. The hitch height should position the bed of the trailer parallel to the ground
All three of those done right will will result in a trailer that will not sway, porpoise and will have the least drag.
I weight cabinets, spare tires, tools and anything else to be in the trailer and distribute that weight. All needs to be factored in not just the bike.
If you have a trailer and load that approaches 3,000 lbs a load equalizing hitch should be installed. I even use it for a 6'X12' single axle. I can be in strong cross winds going down a grade with a semi passing and it will track like it was on rails.
That's the 8.5' X 20' rig that I towed for 7 years. Before that I had a 6' X 12' single axle that I towed for 7 years. I'm currently back to a 6' X 12'. For three decades prior to those trailers I pulled big boats. towing is serious business and is risky like riding a motorcycle.
