Do I need a starter
Old Mar 24, 2015 | 05:02 PM
HD daddy's Avatar
HD daddy
Stage IV
Default Do I need a starter
Hey all out there!! I have a 2005 heritage softail. The issue is the starter will spin but only engages the jack shaft when it wont's to. Should I wait to order a new starter or remove the old one and see if there's a bad spring I'm undecided. Any Ideas would be a great help. THANKS!!
Old Mar 24, 2015 | 05:07 PM
HDmikie's Avatar
HDmikie
How old is your battery? How many miles on bike? Do you make lots of stops and have to start your bike a lot?
Old Mar 24, 2015 | 05:17 PM
Mr HOG's Avatar
Mr HOG
First, I would check all your electrical connections and make sure your battery is good. If all that checks out and it still does the same thing then it's more likely going to be your starter bendix and/or solenoid is not engaging the flywheel properly. Pulling the primary cover and engaging the starter will probably give you a better idea of what's wrong. With the cover off, just plug the plugs so the engine won't start.
Old Mar 24, 2015 | 07:16 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Intermittent jackshaft engagement could possibly the starter drive clutch.
Old Mar 24, 2015 | 08:06 PM
hdbob2006's Avatar
hdbob2006
If it fires up easily when the jackshaft DOES engage,No you don't need a starter.
Old Mar 25, 2015 | 01:14 AM
1Canuck's Avatar
1Canuck
sounds familiar. on my third starter clutch. get it done sooner than later
thirsty
EVO
14
May 16, 2019 11:03 AM
johnfairclough
Jul 26, 2012 07:32 PM
Bama91
EVO
55
Mar 11, 2011 06:36 AM
Bullys FLSTN
EVO
Sep 5, 2009 06:36 AM
harleyboy63401
Jul 15, 2006 12:55 AM
