Always stay in 1st in case you have to make a quick maneuver to avoid being rear ended or move fast for some reason. Left foot down, right foot on the board or peg so you can turn quick and tight with the braking trick.
Originally Posted by mayhemmaster
never coast... neutral is reserved for parking your bike
you wanna b in gear and ready for what ever comes your way
Originally Posted by Mike Lawless
What FloridaHarleyRider said.
Originally Posted by Coastal CVO
Didn't we have this discussion over a year ago...
In gear, in neutral, are you going to get rear ended, will you be able to get out of the way quick enough.
If I know the light is going to be long, nuetral, if I am not sure, in gear.
Let your left hand be your guide.
Originally Posted by ChickinOnaChain
The ONLY time I put it in neutral, is when I kill the engine to park it...unless I'm not on a lever surface. Then I put it in first.
And to Coastal CVO...probably.
Originally Posted by Nomadmax
You have six controls on a motorcycle that can change only two things; speed and direction. Riding a motorcycle in neutral for any period of time is giving away one of those two things. Doing that seems counter productive, especially in an area where other vehicles may or may not stop behind you (intersections).
Riding in neutral for any distance is akin to opening the cylinder of a revolver just before a shoot out. That said, I'm only a fanatic about my safety; somebody has to post the "I got ran over by a car approaching a red light" thread.
Originally Posted by LonestarXL
I never coast in neutral, that's an accident waiting to happen. A quick application of heavy throttle has saved my a** many times at slower speeds, with cars changing lanes unexpectedly.
Having said that, if I've been on the bike in a ton of stop and go, or on a really long run, and I come to a stop, and the traffic behind me is all stopped, I'll flick it in neutral to give my clutch hand a rest. But that's the exception not the rule for sure.
Originally Posted by SanJuanRon
NEVER coast in neutral! Stay in gear and downshift as appropriate. SJ Ron
Originally Posted by Donnybrook
Downshift, let the engine do most of the braking for you.
Originally Posted by DMWyant
I always downshift and let the engine do some of the braking. The only "coasting" I do is with the clutch pulled in. Coasting in neutral just isn't safe.
Originally Posted by Daytona Fat Boy
What Mike Lawless said.
Originally Posted by upflying
You are not in control if you coast or stop in neutral. Always stay in first gear when stopped in case you need an emergency getaway. Where do you put your gas cap when fueling?
Originally Posted by keith_stepp
Really bad idea. The only time my bike ever goes into neutral is when I start it, or I have to reach into a pocket for whatever reason with my left hand and that is very rare.
Originally Posted by TinCupChalice
Brake pads are cheap... engines are expensive I come from the rev match downshifting school of thought and use the brakes to stop the bike. I do the same with my Turbo 6 speed manual automobile, too...
As to the OP, my bikes are only in neutral when first started and when I turn the ignition back off, I'm unwilling to sacrifice control. There's times you need the brakes for accident avoidance, there are other times you need the throttle to save your butt
Originally Posted by Colorido
OP, if you want to coast, pull the clutch in!
But keep downshifting to match gear to speed (you don't have to let the clutch out and ruin your coasting) in case you need to get out quick.
Coasting in neutral is just asking for trouble...too much time to get it back in gear if you have to make any quick maneuver.
Originally Posted by jmn1960
allways stay in gear!!!!!!!!!!!!!!!!!
Originally Posted by SPRINGER
I leave it in gear when coming to a stop and it's in 1st gear when stopped.
Originally Posted by dav500
^^^^This is what I do too. ^^^^
Originally Posted by SG_Jim
Yep, what he said.
Originally Posted by bdtaylor1979
Originally Posted by Mustangtcs
In a car you were told to put it in neutral and the reason is leaving it in gear with the clutch depressed wears the throwout bearing fast. In order to do the throwout bearing you have to drop the tranny and pull the clutch. So now your on a Harley and don't have that issue. I downshift and stop with my headlight in someone's side mirror which puts me on either side of the car in gear ready to exit if need be. I had a truck go in reverse and floor it and almost run me over one day because he didn't see me in the mirror. Be safe and strengthen your left forearm!
Originally Posted by TriGeezer
As it is taught in MSF courses.
To the OP, seeing a trend here? NEVER coast in neutral, ALWAYS keep it in gear while stopped.
Stay in gear at red lights so you can get the hell out of the way if a dingbat comes up from behind watching the car in front of you - they literally can look right through you.
The only time I put the bike in neutral when out on the street is if it is being a long traffic light and I already have several cars stopped behind me so I don't have to worry about being rear ended. Otherwise, I downshift to stop and keep it in first until the light turns green, constantly checking my mirrors for zombies.
I have been driving standards my whole life and never use neutral until/unless I am shutting down. When I did my driver's test (1964) they'd fail you for going into neutral on the road!
The only exception might be if I was sitting at a LONG red light. If all the traffic behind me is stopped, I will sometimes switch to neutral to give my hand a rest.
Preference really, I like to shift into neutral 35 yards out coast to a stop, sometimes while standing on the floor boards. It gets good looks from the others waiting in the intersection.
LOL hell, I wouldn't trust the floorboards to hold me up, even at just 200 lbs.but that's funny visualizing someone pulling an azz clown stunt like that.
Just showing off. One of our products is an N1 shift system, meaning neutral is all the way down on the bottom. Neutral..1st..2nd...3rd...etc. Got have a little fun once in awhile.
