downshift or shift into neutral
Old Apr 21, 2015 | 02:50 PM
noraA's Avatar
noraA
Default downshift or shift into neutral
When coming to a stop is one method better than the other or simply preference? I find myself just shifting and coasting while in neutral. How about you?
Old Apr 21, 2015 | 02:56 PM
corliss@bakerdrivetrain.com's Avatar
Preference really, I like to shift into neutral 35 yards out coast to a stop, sometimes while standing on the floor boards. It gets good looks from the others waiting in the intersection.
Old Apr 21, 2015 | 02:57 PM
Pix's Avatar
Pix
Depends on traffic and situations, no control coasting, if I need to get out of a problem that split second of acceleration can mean the difference, also stopped I will only go into neutral when all traffic behind has stopped.
Old Apr 21, 2015 | 03:00 PM
FloridaHarleyRider's Avatar
FloridaHarleyRider
Always stay in 1st in case you have to make a quick maneuver to avoid being rear ended or move fast for some reason. Left foot down, right foot on the board or peg so you can turn quick and tight with the braking trick.
Old Apr 21, 2015 | 03:02 PM
mayhemmaster's Avatar
mayhemmaster
never coast... neutral is reserved for parking your bike
you wanna b in gear and ready for what ever comes your way
Old Apr 21, 2015 | 03:07 PM
Mike Lawless's Avatar
Mike Lawless
What FloridaHarleyRider said.
Old Apr 21, 2015 | 03:08 PM
Coastal CVO's Avatar
Coastal CVO
Didn't we have this discussion over a year ago...
In gear, in neutral, are you going to get rear ended, will you be able to get out of the way quick enough.
If I know the light is going to be long, nuetral, if I am not sure, in gear.
Let your left hand be your guide.
Old Apr 21, 2015 | 03:16 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
The ONLY time I put it in neutral, is when I kill the engine to park it...unless I'm not on a lever surface. Then I put it in first.
And to Coastal CVO...probably.
Old Apr 21, 2015 | 03:25 PM
Campy Roadie's Avatar
Campy Roadie
You have six controls on a motorcycle that can change only two things; speed and direction. Riding a motorcycle in neutral for any period of time is giving away one of those two things. Doing that seems counter productive, especially in an area where other vehicles may or may not stop behind you (intersections).
Riding in neutral for any distance is akin to opening the cylinder of a revolver just before a shoot out. That said, I'm only a fanatic about my safety; somebody has to post the "I got ran over by a car approaching a red light" thread.
Old Apr 21, 2015 | 03:38 PM
LonestarXL's Avatar
LonestarXL
I never coast in neutral, that's an accident waiting to happen. A quick application of heavy throttle has saved my a** many times at slower speeds, with cars changing lanes unexpectedly.
Having said that, if I've been on the bike in a ton of stop and go, or on a really long run, and I come to a stop, and the traffic behind me is all stopped, I'll flick it in neutral to give my clutch hand a rest. But that's the exception not the rule for sure.
