Big Radius pipes.
Old Apr 25, 2007 | 10:57 PM
Drtbag's Avatar
Drtbag
Default RE: Big Radius pipes.
In my opinion the baffles would pass as "mufflers" look in the end of the pipe and you can see some attempt at restricting the exhaust flow.
I just pulled the baffles out and cut the front end of the baffle and bent the pieces inward so the internal end of the baffle looked like a cone. I reduced the opening of the baffle by about 1/2. Put them back in and there is a noticable difference. they are a little quieter, didnt seem to effect performance at all.
Old Apr 26, 2007 | 03:51 AM
Punkpogoer's Avatar
Punkpogoer
Leave the baffles in, they sound great......have a listen.http://www.youtube.com/watch?v=IBZRNIWRGZs
Old Apr 26, 2007 | 04:12 AM
SpeedsterX's Avatar
SpeedsterX
ORIGINAL: Crazy Biker
You will lose torque with no baffles. You need that back pressure.
DITTO!
Take them out and you are going to need at least $800 bucks of "chipping", "Dyno testing" etc...
They sound great with the baffles!!
Old Apr 26, 2007 | 09:53 AM
George C's Avatar
George C
ORIGINAL: okiehogg
Stupid question, but are the baffles considered mufflers? I know my state requires muffles, but not sure if it has to be a "visible" muffler.
Baffles are not mufflers. There are no "chambers" in a baffle.
The enemy of a free flowing, unbaffled pipe is reversion. Reversion is where exhaust actually gets sucked back in to the combustion chamber before the valve closes, thus robbing the new gas charge of oxygen and fresh gasoline to burn. Without oxygen & gas, there is no burn, and that kills power.
A baffle increases backpressure slightly, but more importantly, the backpressure helps with reversion.
Take your baffles out and you'll see a dramatic drop in power because your combustion chamber is being refilled with exhaust..
There are a lot of cutsie exhaust pipes out there. Most don't have any baffling. Look great, run like $hit.
Pick a system like V&H, Hooker, Samson or any other performance baffled pipe to get the power that you should get with an exhaust change.
Old Apr 26, 2007 | 10:21 AM
ckgdrums's Avatar
ckgdrums
I agree with the others...leave 'em in. They sound great!
Old Apr 27, 2007 | 04:26 PM
ClinesSelect's Avatar
ClinesSelect
I bought a set for my Fat Boy when they were just released so I had never heard them before. Got done installing them in the garage around 10pm and, of course, I wanted to hear how it sounded. So I closed the garage door in our incredibly quiet neigborhood so not to disturb the neighbors and started it up...
[sm=jawdrop.gif]
Leave the baffles in.
Old Apr 27, 2007 | 06:15 PM
drrandall1's Avatar
drrandall1
Oh yah, love the sound. Especially in the garage!!!![sm=happybounce.gif]
TxChris
Exhaust System Topics
Feb 8, 2016 09:06 PM
07BlueScoot
Feb 9, 2010 09:34 PM
09B29
Nov 17, 2009 11:00 PM
Booey424
Feb 16, 2008 04:51 PM
JohnK/Pa
Dec 26, 2006 05:24 PM
