For what it is worth The helmet that saved my life got dropped, kicked,
and got knocked off of the counters many times between 2001 and 2007.
It still did just what it was meant to do when the time came.
If you just have a brain bucket it doesn't matter.
If you have a real helmet, a short fall can damage it. If you've ever cut tile or drywall you understand how just a scratch can have major change in how an impact will make the material fail.
Helmets are made to fail in a controlled manner to absorb and dissipate energy. Even dropping a helmet can essentially ruin it. However you can have them checked and often even repaired for not a lot of money so it's not a given that they need to be tossed.
What is a "real helmet" ?? I guess a DOT approved half helmet isn't real ? I also suppose if you are incredibly ugly you need to wear a full face....I hope you enjoy all your gear with Kevlar, pads, and leather. Hope it lights up and inflates upon impact also.....
Ah, another "where do you put your helmet thread".
I would reckon seeing skid lids on the ground is a subliminal message on what the helmet owners think of helmet laws.
That and they make a nice prop for the kick stand on soft or wet dirt, used one as a jack stand so I could change the rear tire once
