Navigating Steep Downhill Twisties
For instance if I am aiming for 40mph I will let it go to 45 and then actively brake to 35 and allow the engine to slow acceleration back to 45. Then repeat.
Don't get stressed if there is a vehicle behind you, just do your thing and worry about you. If there is a pull over let them pass so you can focus. Go slow, stay in your lane especially around blind right corners stay away from the center line a bit as a passing a vehicle may be riding over the line.
An Ultra Limited is a big bike to be learning on so just stay relaxed and take your time. Before long it will all be second nature.
Ride your ride and don't worry about the guy behind you. I was taught to be on the brakes half as much as you are off them. So for every 5 seconds of braking you should be off of them for 10. General rule also is 1 gear lower than it took to climb that same hill. If you would climb that hill in 3rd, then you will probably need 2nd gear.
With some more miles under your belt you will laugh at how you used to have to think about it!
You should also be proud by the way, lots of people never take their bikes out of town!!
And Keith Code was a great racer, but he got completely new brakes for every race-
Don't worry about operating your HD in the 3,000 - 5,000 rpm range, the new engines are made to rev! That's the factory recommendation, and also the service manager's advice at both HD dealer shops where I have my work done.
You better use engine braking coming down this one. I don't think brakes would last all the way to the bottom without it.
