Spot lights not working
Old Jun 24, 2015 | 06:09 PM
LowRider68's Avatar
LowRider68
Default Spot lights not working
I have a 2007 Deluxe and the spot lights aren't working. I checked all the fuses and they look good and all the other lights work. I flipped the switch to its other position and that didn't solve it.
Anyone have any ideas what I should check next?
Thanks in advance!
Old Jun 24, 2015 | 06:13 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Terminals corrode or vibrate loose, check them for voltage at the switch would be where I started. Got voltage in I suspect but none out, clean the terminals.
Old Jun 24, 2015 | 06:18 PM
LowRider68's Avatar
LowRider68
Thanks, I will check the switch.
Old Jun 24, 2015 | 09:02 PM
nevil's Avatar
nevil
Looking at a fuse is not the best way to determine if it's good or not. I've had a fuse or two that looked fine, but put a meter on it and found out otherwise.
Old Jun 24, 2015 | 09:12 PM
mikelikesbikes's Avatar
mikelikesbikes
What does the toggle switch feel like? Mine went south so I just hard wired it together so they are always on, which I prefer.
Old Jun 24, 2015 | 09:19 PM
pcbreflections's Avatar
pcbreflections
Dont forget about the ground wire
Old Jun 24, 2015 | 09:26 PM
Loc_Tite's Avatar
Loc_Tite
You're sure it's not the bulbs? A short in that circuit takes out the headlight also...
Old Jun 24, 2015 | 09:27 PM
Ragtop's Avatar
Ragtop
sometimes a squirt of contact cleaner will help a dirty switch.
easy enough to try.
jf7689
EVO
Sep 24, 2015 05:19 AM
just plain john
Nov 10, 2014 11:09 PM
Staggerty
Jul 8, 2011 12:24 PM
Lucky1958
Electrical/Lighting/Alarm
Dec 2, 2010 01:59 PM
sincityharley
May 23, 2007 03:14 AM
