Driving lights failure
Old Dec 1, 2010 | 02:12 PM
Lucky1958's Avatar
Lucky1958
Default Driving lights failure
05 deluxe
driving lights go out about every 3 months one or the other will go out. Previous owner said the same.
I have chech switch and connection and dont find a problem.
Any ideas
Old Dec 1, 2010 | 02:55 PM
UltraNutZ's Avatar
UltraNutZ
they go out or the bulbs burn out?
Old Dec 2, 2010 | 12:29 PM
my1sthog's Avatar
my1sthog
Check the connections under the fairing. A bad ground or connection will cause them to get hot and burn out prematurely
Old Dec 2, 2010 | 12:42 PM
peppi's Avatar
peppi
Originally Posted by Lucky1958
05 deluxe
Any ideas
Being you checked the switch, is it working properly with power on both sides when it is on?
Have you checked for corrosion at the fuse panel?
Like asked above, do they go out (off) or are they blown out bulbs ?
Old Dec 2, 2010 | 01:59 PM
JohnnyC's Avatar
JohnnyC
You didn't say much about the driving lights themselves. H/D or aftermarket? Design for a vibrating motorcycle or designed for a car?
Could be that when you turn on heavy duty driving lights you put your charging system under a heavy load. Often the bike with driving lights is set up to run low beam headlights with the addition of the driving lights so you don't have a huge draw on your charging system.
Filaments go bad for a few reasons. Too much voltage. Not a clean DC voltage feeding them, like in a bad regulator. Vibration is hard on filaments too. Perhaps placing a better quality bulb, or sealed beam in the holder would stop the problem.
I would make certain the lights are designed for use on a motorcycle if they were just some aftermarket units.
jf7689
EVO
Sep 24, 2015 05:19 AM
LowRider68
Jun 24, 2015 09:27 PM
Jim Dawson
Jan 27, 2015 10:43 AM
just plain john
Nov 10, 2014 11:09 PM
sincityharley
May 23, 2007 03:14 AM
