Softail wheels ?
Old Jul 10, 2015 | 07:37 AM
mountaincycle's Avatar
mountaincycle
1st Gear
Default Softail wheels ?
Will a set of 2007 softail wheels fit a 2003 softail (fatboy) ?
I know both front and rear are 16" but are the axels and spacing the same?
Thanks in advanced!
M
Old Jul 10, 2015 | 07:48 AM
Mikey 1450's Avatar
Mikey 1450
Not 100% but, I believe the 07 had a wider rear wheel than the 03, so fit wise, probably not.
Old Jul 10, 2015 | 07:52 AM
Bluraven's Avatar
Bluraven
You might want to post this in the Softail section of the forum.
What I do when I'm looking for fitment references is I find the part that fits my application.
Then I find the donor part and compare the part numbers.
If the parts numbers are the same then they are compatible.
More specifically to you question:
Go to the Harley site and look up a replacement wheel for a 2003 Fatboy.
Then under the "Fitment" tab see if the 2007 donor bike is listed.
If it's listed then the wheel from the 2007 donor bike will fit the 2003.
Old Jul 10, 2015 | 08:03 AM
QC's Avatar
QC
At the very least the axles and bearings are different. '03 is 3/4 diameter.
Old Jul 10, 2015 | 08:08 AM
mountaincycle
1st Gear
Thanks gentlemen...
Kennypatterson
Sep 2, 2015 05:36 AM
RikL777
May 2, 2013 04:16 AM
eddyp
Apr 2, 2011 09:48 AM
harleylay
Feb 15, 2010 07:34 PM
Baghdad Charlie
Sep 8, 2008 08:28 AM
