Rust on shift rod joint
Old Jul 17, 2015 | 09:34 PM
bdtaylor1979's Avatar
bdtaylor1979
Default Rust on shift rod joint
I noticed some rust on the front joint of the shift rod on my bike today. Is this anything to worry about and should I just replace it? The bike has 96,000 miles on it.
Old Jul 17, 2015 | 09:39 PM
Uncle Larry's Avatar
Uncle Larry
Heim Joints ... there's a thread on how and what to replace.
Old Jul 18, 2015 | 12:37 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
I would definitely replace the bike ASAP before it all goes to hell in a hand basket.
Old Jul 18, 2015 | 01:14 AM
JohnMn's Avatar
JohnMn
Uhm, Yeah,, it's time to fix that. Easy enough.
Best to fix it than have it break when your out enjoying a ride and it decides to let go leaving ya no way to shift.
It'd be a bum ride home stuck in 2nd gear.
Old Jul 18, 2015 | 06:59 AM
big cahuna's Avatar
big cahuna
I spray chain lube on them every now and then to lubricate the ball, and keep it from rusting.,,
Old Jul 18, 2015 | 09:19 AM
Crashone's Avatar
Crashone
Here's a link to what I did. The shifting is tight and no slop in the linkage.
https://www.hdforums.com/forum/evo-c...l#post14174456
Hope that helps, if you have any questions I can help with, PM me.
Ride Safe.
Old Jul 18, 2015 | 09:20 AM
Nitro 54's Avatar
Nitro 54
Oil it sometimes
Old Jul 18, 2015 | 09:28 AM
RK4ME's Avatar
RK4ME
When my RK's original shift linkage failed, I taped it back together with the electrical tape I had in my tool kit. I replaced it with SE linkage the next day. The Screamin' Eagle linkage has a Heim joint.
Old Jul 18, 2015 | 10:40 AM
bdtaylor1979
Thanks for all the suggestions and help. I never thought to spray oil on it since it has the rubber boot covering the joint. I got one of HD's round shifter rods with the heim joints and will swap it out today or tomorrow. Thanks.
Old Jul 18, 2015 | 10:41 AM
Coolaid's Avatar
Coolaid
Rubber boot just traps moisture...
