A water cooled engine with a thermostat will operate in a very narrow temperature band.
An air cooled motor is not like that. It's operating temperature is going to vary based on how hard the motor is running, the ambient temperature, and the airflow going over the motor.
If you want to have something new to worry about, you can fit an oil temp gauge for cheap.
You would have to buy the oil tank cap with thermometer. Temp should be ta the most 200 degrees. Mine usually is around 175, but on a hot day running hard, yes 200-250 could be reached. 250 is a little high though Im thinkng
I need a sportie. I run 220 until it gets in the 50's outside and then I'm finally dipping below 200. Remember, the oil temp gauges are oil temp only. Head temps are much hotter. 400* isn't unreasonable depending on where the sensor is.
