I've only scraped my foot peg once, going around a corner that had a dip, like for rain. It really surprised me. Other than that, I don't lean into a turn like I'm riding a sport bike.
Just for the record. A sport bike and a Harley, when ridden through a turn with the same body position and speed, will both require the same lean angle.
Your statement is a bit ambiguous, and this is a common misconception. That's why I'm pointing it out.
Please explain how wheel base, rake and trail has nothing to do with lean angle... I'm all ears
Wheelbase: turning radius...this doesn't really matter in most turns beyond very low speed u-turns
Trail and rake: to put it simply, these are about straight line stability and how responsive a bike is to turn
I may be crazy, but there is a science to all this that is typically not discussed or understood by most people. There's a lot to read out there.
The bottom line is that on a typical corner it doesn't matter if you're on a mountain bike, a softail, or a superbike, if your speed, body position, and line are the same, you'll be at the same lean angle. That's just how single track vehicles work. There's no magic here, just science.
I'm all ears for a valid response explaining exactly why I'm incorrect.
