Ground Clearance
Old Aug 29, 2015 | 01:51 PM
  #41
jimjlips's Avatar
jimjlips
If you are not scraping your scared to ride or in Florida
Old Aug 29, 2015 | 02:02 PM
  #42
jimjlips's Avatar
jimjlips
Default camber?
Did you mean caster? I think camber would only apply to something adjustable like king pins or equal
Old Aug 29, 2015 | 07:05 PM
  #43
Randy Mac's Avatar
Randy Mac
Originally Posted by Next In Line
Look up Negative Camber.
Are you thinking of road crown? Negative camber is what made old VWs look like they are squatting to pee.
Old Aug 29, 2015 | 07:26 PM
  #44
IdahoHacker's Avatar
IdahoHacker
Originally Posted by TinCupChalice
...Proper throttle control and roll-on, corner entry, and body position all have a huge role in keeping the hard bits from touching down...study cornering theory and practice it. The goal is a continuous throttle roll-on and a late turn-in. Don't just sit there on the seat; get your body weight to the inside of the turn...
This^^.
Yes, there are certain Harleys, like Deluxe and Heritage Classic, that have very low ground clearance and not much lean angle. However, even with these models, if you understand body position and how it affects lean angle, and you understand when to roll on, and you understand how to turn a motorcycle, there is no model that you cannot go bombing through the twisties on and have all the fun you want.
Old Aug 30, 2015 | 03:53 AM
  #45
BoonDock_Saint's Avatar
BoonDock_Saint
Originally Posted by GCW
This idea annoys me so much that I'm reluctant to buy a cruiser and just find a different type of bike I like with out the scrape issue. Are there any cruisers that don't have this issue?
Funny. My Apples don't taste like oranges either.
Old Aug 30, 2015 | 06:49 AM
  #46
Bart van der Meulen's Avatar
Bart van der Meulen
Take a 4x4 or a F150...Sure ground clearance enough...My Heritage Classic was known for his scraping sounds on roundabouts, corners and U-turns. Scared more the hell out of bystanders and other riding mates than it scared me. I knew how to scrape it safely..Disadvantage? Every two year new floor boards. The last pair I adapted with a renewable gliding strip, lifting the floorboard during scraping, preventing to get hooked behind stones and preventing the body of the floorboard to be grinded.
Old Aug 30, 2015 | 06:51 AM
  #47
Bart van der Meulen
Originally Posted by OldEnuf2NoBtr
Yes there are. They're called automobiles.
Old Aug 30, 2015 | 08:20 AM
  #48
Next In Line's Avatar
Next In Line
Camber: How Does it Affects Us?
Old Aug 30, 2015 | 08:25 AM
  #49
nevada72's Avatar
nevada72
Proper riding techniques and bike setup will mitigate many of the problems experienced on a cruiser styled bike with ground clearance issues. My Wide Glide certainly isn't my R1 that I recently sold but it's no slouch in the corners either
Proper throttle control and roll-on, corner entry, and body position all have a huge role in keeping the hard bits from touching down. Set your suspension to its stiffest settings, study cornering theory and practice it. The goal is a continuous throttle roll-on and a late turn-in. Don't just sit there on the seat; get your body weight to the inside of the turn...
Winnah!
Old Aug 31, 2015 | 03:46 AM
  #50
turbotom1052's Avatar
turbotom1052
Originally Posted by nevada72
Winnah!
if I remember correctly I think Harley sets up the rear suspensions at the factory for a 180 lb rider. I haven't weighed 180 lbs since high school. Every Harley I've ever owned has required the rear suspension preload to be stiffened up a bunch to suit my weight and riding style. Mt latest and lowest softail Deluxe would scrape the footboards even when not riding aggressively. For the Deluxe I wound up having to go with full preload on the rear. The ride is a little stiff, but it no longer scrapes. As an added bonus I can now get my jack under the bike to lift it up. Before that it would not roll under.
