Weird start..
Old May 5, 2007 | 10:38 PM
michaelbarry's Avatar
michaelbarry
Default Weird start..
I went out to start the bike up this evening...she is a little tough to get started, but I eventually did...and it was running AWFUL. Backfiring through the carb and pipes..spitting, sputtering. It dies. I'm thinking..oh god. Try to start it again..and it's like it wants to start, but it won't. Keep cranking..finally got it turned over..but it's running awful again..so I let it die (won't idle, so I just let off the throttle). I flipped the petcock over to "Reserve" and hit the starter button...fired right up and ran smooth as usual. Pulled out of the building, and turned the petcock back over to "On" and it was fine. Any idea what may have happened?
Old May 5, 2007 | 11:24 PM
ZD's Avatar
ZD
Default RE: Weird start..
Quite possibly agrimble of water in the fuel.
Old May 5, 2007 | 11:47 PM
HD7585's Avatar
HD7585
Your float was stuck in the down position, delivering way to much fuel. Mine dose it once a year or so. To free it up i close the petcock and run the carb out of fuel. This always works foe me. Or you had a speck of dirt on the fuel seat.......Same result
Old May 5, 2007 | 11:50 PM
michaelbarry
Whew..I'm glad it's nothing to worry about. Thanks alot, guys. I was a bit worried
Old May 5, 2007 | 11:55 PM
HD7585's Avatar
HD7585
You might want to run some HD fuel treatment through it........It seems to help mine
DonB5150
May 22, 2023 03:24 PM
Tileman2692
Nov 23, 2016 03:10 PM
ez__rider
Carburetor Related
Mar 20, 2015 04:10 PM
apetterez
Sep 25, 2014 06:39 PM
dm76
May 29, 2009 10:33 PM
