Pan let me down today
Old May 6, 2007 | 01:31 AM
YUCK's Avatar
YUCK
Default Pan let me down today
Crankysumabit%%....the Flatty and Pan roll outta work today,,,we're tooling up the road and my pan starts bleeding,,,look down at the pressure gauge,,Damm,,,the glass is cracked and its bleeding to death smack dab in the middle of Bumbfu** Nowhere,,,,Hmmm think to myself,,,not bleeding too bad,,,,I can make it to a town hardware store and plug it,,,10mins later the back break binds and I'm still in the middle of Bumbfu** Nowhere sitting on the side of the road watching the cows chewing and dumping and my bike bleeding to death...but its a nice day and the sun is shinning and the bike is cool enough to back off the rear break...no biggy,,,I'll use the front brake to get back to our shop,,,BTDTB....OK 14 mountians later andthe frount brake starts to fade,,,,Damm comming down the last hill,,,,to the red light,,,front brake gone,,, 1st gear screaming rolling through the RED light,,,looking to T-bone 60-70mph traffic flow,,,Damm,,,hard right,,, scrapping pipes,,, on the shoulder as 6 cagers blow by,,,kewl they missed me....its all up hill from here....grab some gears and roll into the shop....throw up the door,,,put the Flatty and Pan to bed.....All in all it was a good day....
Old May 6, 2007 | 10:04 AM
YUCK's Avatar
YUCK
Default RE: Pan let me down today
Nobody else have a bad day???
Old May 6, 2007 | 10:41 AM
pococj's Avatar
pococj
LOL, that ain't a bad day! Yer walkin, right? What caused the rear brake problem?
Old May 6, 2007 | 02:30 PM
grunt's Avatar
grunt
ORIGINAL: YUCK
Not bike related, but spent almost 5 hours running 5 measly damn wires in my girl's house. 2 for the sat, 1 phone, 2 speaker.
Starts out when I could not get the fish tape to go up the wall (outside wall, insulated). So I try from the top, easily drill thru the plate. Tape on the wires, down the hole. Nothing. Almost stuck in the wall pulling up. Try several other times, even w/1 wire. No go. Attic is hot. Sweating buckets. Cussing like a mechanic by now (and evidently f-bombs have more sonic heft than 'You see anything?" as my girl heard those and not the questions).
Gonna go thru the closet wall, but she like the idea of the ceiling corner so I do that. When the phone line was moved the wire positions were not marked, so we had to pop the top off another one and get the scheme.
Get the wires run, and the right speaker wire is too short to hook on the easy way, so I had to hold the receiver while she screwed them on blind. And somehow pulling the receiver in and out breaks the easy pins on the other wires, so haveta reconnect them.
Sooo, turn on the DVR and no signal. Pull it back out, reconnect the tuner cables, try again. Get sat chnl 1, no 2. Reconnect 2 on the DVR. Nothing. Go to the wall plate, and pull off 1, then reconnect to prove it will work again. Then put 2 in 1's slot. 2 lights up. So the plate->DVR connections are good. Start checking the back, and while I was holding the cables both channels light. Meaning the coax was broken on the inside. Luckily it was the first 6", but I did not bring cable strippers (Yeah, baby ). Using a steak knife, I whittle the cables down after hacking them off. Since for some reason I brought some cable connectors I was able to get both to work again. Pushed the wires up the attic hole and put the shelves back in, and FINALLY a working stereo system. Started at 8pm, finished at 1am.
Will never have another house (built) that does have wire runs on every wall, and every entertainment-possible room will have the speaker jacks in the walls and ceilings. [:@]
Old May 7, 2007 | 12:42 AM
YUCK's Avatar
YUCK
Pococj...I think its the master cylinder, gonna get it on the table this week..picked up a pair of brand new front shoes a brohadsittingaround for decades....
Grunt,,,Damm,,,sorry about your luck....My bad day was better than yours,,,,5 hours for DVR,,,U should try and wire sumthing in my house,,,,plank,,,built in the 1880's,,,I prefer chainsaw,ducktape and buck knife,,,for my wireing needs...
Fullbore55
Audio Systems
43
Oct 21, 2018 06:16 PM
SnoRider
Nov 10, 2015 10:07 AM
roussfam
Audio Systems
34
Aug 1, 2015 08:41 AM
Nautilus
Sep 17, 2009 05:22 PM
Kbore
Jun 13, 2009 01:45 AM
