Torque Master
Old Dec 8, 2015 | 09:20 AM
fra107's Avatar
fra107
Default Torque Master
Hi guys,
i mounted motorcycle Torque Master spark plugs and used them about 2 weeks.
I've had idle problems with them, my bike suffered at cold start idle and sometimes it switches off itself, when it happens a dark smoke come out from the air intake.
I remounted the stock spark plugs today and everything is ok now.
My bike is a 2012 96ci wide glide, with full stage 1 on it.
Someone tried Torque Master spark plugs?
Is my bike wrong or what?
Thanks
Old Dec 8, 2015 | 09:33 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
No, it's the Torque Master plugs. Harley's use a spark plug that is deigned for their bikes that uses an ion sensing technology that the ECU can recognize.
Old Dec 8, 2015 | 09:57 AM
AFDynaRider's Avatar
AFDynaRider
I would recommend you keep using Harley plugs or equivalent. You aren't going to gain anything from any of the fancy gimmicky go faster spark plugs.
Old Dec 8, 2015 | 01:22 PM
Bubba Zanetti's Avatar
Bubba Zanetti
I've tried 3 or 4 different spark plugs in my bikes over the years. None of them, even the expensive "high performance" ones did not perform any better than the standard HD plugs.
Old Dec 8, 2015 | 01:31 PM
fra107's Avatar
fra107
Thanks guys
Old Dec 8, 2015 | 08:11 PM
FXDXTSport's Avatar
FXDXTSport
Gotta give you credit though. You actually found a replacement part for a Harley that cost more than twice as much as the OEM part. That's hard to do.
Old Dec 8, 2015 | 09:39 PM
Iron lHorse's Avatar
Iron lHorse
I'm thinking cams not spark plugs.
Old Dec 10, 2015 | 12:40 AM
103 sedona orange's Avatar
103 sedona orange
Exclamation Come On Man
The OP removed the Torque Master plugs, reinstalled the OEM & his bike ran fine. Cams?
skywalker204
28
Nov 27, 2017 07:25 PM
fra107
The Dyno Room
May 18, 2016 05:17 PM
Jacob McMahon
Nov 18, 2015 12:27 PM
congo_usmc
Aug 30, 2009 09:54 AM
corona
Exhaust System Topics
Mar 5, 2007 08:34 PM
