Why is my brake light on after Changing my Handle bars
Old Jan 4, 2016 | 07:56 PM
Iceman24's Avatar
Iceman24
See this guy here...you probably broke it, if not shimmed:
Why is my brake light on after Changing my Handle bars-60-1698handlbarswtch.jpg
This is what it looks like in the control casing:
Old Jan 4, 2016 | 08:42 PM
roussfam's Avatar
roussfam
Been there done that, won't happen again
When all else fails read the instructions
Jim
Old Jan 4, 2016 | 10:31 PM
scoriden's Avatar
scoriden
Fix for broken switch.
I did the same thing a few years ago. If you look closely at the switch, you will see a little bump where there used to be a small teet about 1/8 in long.
To repair, I bought a nylon screw the same diameter as the little teet that broke off. About 3/32 if I remember correctly, just take a quick measurement when you are in there. Then cut it to length and use some good epoxy to attach. I have been running mine for a few years, about 20K miles and it has held up fine.
Or you can change the switch, not particularly difficult, just a pain.
Old Jan 5, 2016 | 10:29 AM
skratch's Avatar
skratch
i admit it. i broke mine too. the way i fixed mine was to drill a small hole in the brake lever and then screw a small screw in there so that the 'button head' would act as the 'tit' to depress the switch.
Shovelhed
Mar 7, 2017 03:48 PM
thumper89
May 2, 2015 03:19 AM
67bullitt
Nov 11, 2010 07:48 AM
2007z71
Jul 15, 2008 09:18 AM
LT753
Dec 26, 2005 09:00 PM
