Panhead question
Old Mar 22, 2016 | 05:33 AM
Speeding Big Twin's Avatar
Speeding Big Twin
Thanks for the picture of the serial number, Ryan, but it's very blurry. Can you post a clearer photo please. Then I'll compare everything with other examples in my collection.
Eric
Old Mar 22, 2016 | 12:16 PM
ryanneal7223's Avatar
ryanneal7223
Yeah I'll take some better photos when I get a chance
Old Mar 22, 2016 | 12:44 PM
Sling Blade 14's Avatar
Sling Blade 14
Have you checked with Joey's for some assistance?
https://www.facebook.com/Joeys-Custo...-340995042498/
Old Mar 23, 2016 | 11:46 AM
ryanneal7223
No but he is my go to guy for parts and ideas on what will work and won't... He's really busy this time of year so I don't want to bother him with it until I know what all parts I will need.. And also the 48 pan says it has a plumber style intake heads if I bought later heads with the o ring style intake would they bolt on those cylinders fine?
Old Mar 23, 2016 | 12:36 PM
ccislander's Avatar
ccislander
You can use any heads from '48-'62. However, the '58 (I think it was '58-need to check Palmer's book) and later had more fin surface area. They'd still work fine but it's very noticeable that they're not the correct heads for a '48.
Are you going to try to have this motor rebuilt as a 61" or a 74"?
Old Mar 23, 2016 | 03:56 PM
Hocus-Pocus's Avatar
Hocus-Pocus
I'm buying a 48 el case set it's really hard to find el parts so if I bought fl top end would it work? Pistons hugs heads.. Also would a fl rotating assembly work in the case also? Basically could I have a fl in a el case
Check out this guy. His name is Dale Walksler. He knows a lot, and should be able to help you. Give him a call.
http://www.wheelsthroughtime.com/
Old Mar 23, 2016 | 04:50 PM
ryanneal7223
I would like to do 74
Old Mar 23, 2016 | 09:25 PM
panz4ever's Avatar
panz4ever
In 55 MoCo changed the intake manifold from a Plumber-style to the O-Ring style so you would need to change the intake in the heads and use the later type of intake manifold. Places like Carls Cycle Supply will do it for you.
So using later style heads is definitely NOT a bolt-n-go set up.
Curated Content Editor
May 2, 2019 04:02 PM
ryanneal7223
Classic
Feb 1, 2016 04:25 PM
DerekShiekhi
Nov 3, 2015 03:23 PM
harpwrench
Motorcycles For Sale
May 4, 2012 07:25 PM
