running rough
Old May 15, 2007 | 05:33 PM
Dasm's Avatar
Dasm
Stage II
Default running rough
Well here's the situation, the girlfriends 883 sportster's battery went dead. I jumped with the truck (hopefully this was not a mistake- assumed the bike share's a 12v system). I had jumped the battery once before like that and there was no problem.
Anyway, once it was running, the odometer digital was flickering. When I revved the motor, it seemed to be sounding with an irregular pop, like a cylinder was not firing, and seemed to do the same when I actually rode it a very short distance. Also, there was a an audible whirring when as I twisted the throttle handle in neutral.
Is this a common problem, and should I take it in to the dealer (it's outta the warranty period) Any help/suggestions would be appreciated
Old May 15, 2007 | 06:45 PM
T Tommyt's Avatar
T Tommyt
Default RE: running rough
Something happens when you jump with a car(but I don't remember what I read)
look at the electric Forum// do a search
Good luck
Old May 15, 2007 | 07:48 PM
Dasm's Avatar
Dasm
Stage II
Tried running it again in the meantime, it seemed to run smoother but clicked when I turned it off then restarted it. With the battery hooked up to the trucks, the bike ran smooth and the odometer worked fine. Looks like it needs is a new battery is all
Thanks for the reply Tommy. Now I can relax again[sm=sleeping.gif]
peteknok06
Oct 2, 2017 01:57 PM
Anjelica Rose
Apr 10, 2017 06:14 PM
CO Hooligan
Jun 30, 2012 03:21 PM
Robottom
May 30, 2009 05:34 PM
jcrogers61
Oct 21, 2008 07:18 PM
