Cigar smokers
http://www.cigarsinternational.com/a...-clip/#p-10949
I have the same one, use it on the golf cart, but I need both hands to clip the stogie into it. One to squeeze the small clip and one to hold the cigar. Same to release. This could only work while stopped so I never thought to give it a shot on the bike.
BTW,
I smoke cigars every day with Bud Light and don't need some fancy Whiskey to enjoy my stogies.
What about one of these type clips as shown, but with a big (60) ring gage tube clipped to one end of it vertically on the clutch side and the other to the bars or if a bagger, somewhere on the fairing.
Then, when riding, you can drop the cigar with one hand into the cigar tube lit end facing downward, then when ready to draw, grab it with left hand, pull it up and out and take a hit-all while your hand is on the throttle?
Depending on the length smoke you normally use, you will most likely have to cut down the cigar tube some as the ones I have used are too long and the cigar will drop too deep in the tube to grab it. Tube probably only needs to be 2-3" long, so you can always grab the end with your hand no matter how low the burn gets.
I do the teeth thing myself. Just because its sitting there, doesn't mean you have to draw. I breathe through my nose when I don't want to draw on the cigar, or open my lips a bit and breathe around the cigar without drawing air through it. Do get the occasional hot ash hitting my face thought. lol Bugs, rocks and sand hurt worse.
Not sure if they make a clip that would hold your cigar at hwy speeds, that would not damage your cigar.
I learned to enjoy a good chew and now I have a
http://www.motorcyclecupholder.com/product_p/kk200.htm
Too hold my cola can to spit in...~~~~~
proper etiquette is admired.
TN
