Did you happen to wash you bike and spray the wheels directly with water? If so, then you might have affected it.
In 6 years I have washed my bike maybe 20 times. It spends so much time in doors I just wipe it down w detail spray after rides, and rarely ride in the rain. I wash all my bikes 2 or 3 times a year. Just don't get them that dirty.
15 Limited, 18,200 miles: Symptoms were buzzing noise in right turns or leaning bike to the right..
Front right inner bearing was shot..
Just out of curiosity, was the right bearing the only one that was running rough, or was the left also bad. Which bearing has the sensor in it for abs.
I pop a seal on every sealed bearing I buy; many have very little grease, certainly not enough for a wheel bearing. If it's translucent, like vaseline, I clean it out and put quality synthetic grease in it. Never had a bearing failure on a car or bike that I'd put the bearing in. Not just cheap Chinese bearings, either, seen the same in some expensive aircraft bearings. I suspect many of these Harley failures are more to do with inadequate grease than the bearing itself.
Used to use a solvent sprayer, don't have access to one of those anymore, so just wipe out with a rag, get some more with a tiny screwdriver, and sometimes a Q-tip. Gets about all of it, then force grease through one side, wiping the excess off the other, till there's no sign of original grease. Then I wipe some out on both sides, give room for grease to move out when the bearings force a tunnel through the grease - you want room for that after the seals are popped back on. You can see how that works just hand turning it before you put the seals back.
Cool. Wasn't sure if I should go nuts and use something like brake cleaner on it.
Thanks though, I'll take a look when I do the front bearings in the near future.
Would be, I've a couple aftermarket wheels out in the shed the owners just gave up on because of failure issues and not being able to remove the bearings can't see the china wheels doing much better.
Simple. By making the bearing holes oversized and out of round.
