Harley hiccup
Old Jun 27, 2016 | 10:57 AM
Mikez4's Avatar
Mikez4
Stage IV
Default Harley hiccup
I have a 2000 ultra fuel injected and it pulls a code 56 crank/cam sensor, runs good as long as your in the throttle but cruising it spits and sputters, it even idols... I took to shop and put on computer he said only thing he knew was to change both sensors and see..... Any body got any suggestions?
Ok I changed both sensors, still the same are there any other sensors that could be causing my problems?
Old Jun 27, 2016 | 12:28 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Yeah, change both sensors and see.....
Old Jun 27, 2016 | 12:43 PM
OlAndrew's Avatar
OlAndrew
Crank sensor can get covered with metal dust and screw up, fixed with cleaning. On my 2000 RK, when the crank sensor went, it was DEAD. No firing at all. Easy swap, part was about $45 if I remember right. Might be a problem finding one, 2000s are starting to drop off the (computer) parts books at dealers.
Old Jun 27, 2016 | 01:00 PM
Mikez4's Avatar
Mikez4
Stage IV
Thanks I did take out and clean off didn't see and debri or metal, mine runs but not well, I think I found on line for 89.95
Old Jun 27, 2016 | 02:13 PM
Uncle Peepers's Avatar
Uncle Peepers
I've had a crank sensor go twice, and each time the bike would do nothing. Never had a bike just run bad because of a defective crank sensor. Also, each time the sensor failed, it threw no code.
Old Jul 4, 2016 | 06:20 AM
Mikez4's Avatar
Mikez4
Stage IV
I have done that, still the same, what could I do next?
Old Jul 4, 2016 | 07:35 AM
Next In Line's Avatar
Next In Line
Have them do a fuel pressure test. It should be a constant 58 to 62 psi when running no matter what the throttle position is at.
Old Jul 4, 2016 | 10:47 AM
Bodean46's Avatar
Bodean46
Clean throttlebody, check for intake leaks, does it have an add on tuner? When mine did the same thing ( MM system) I had a lean condition at steady throttle, had to fatten it up some. Also check the wire from CK sensor to ECM for a break in insulation.
Old Jul 4, 2016 | 08:16 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
My 2000 Ultra started the hiccup thing at about 75,000 or so miles.
After changing plugs, plug wires, intake seals, etc., etc., bike would NOT "code".
I had to have the Engine Temp Switch replaced and then the bike "coded" indicating a bad ECM (MM of course).
Could not locate and OEM so we went with an aftermarket brand and the bike ran better, but it never started as good as it did before.
Just a word of caution here:
Be sure that your tech has experience on MM system.
THe guy that bought my bike had a S&S EFI system installedand it ran like a "*** out of Hades"
Good luck.
Old Jul 5, 2016 | 10:02 PM
Teachinator's Avatar
Teachinator
Like Next In Line said, check the the fuel pressure. The MM systems are notorious about developing pin holes in the plastic corrugated fuel ones inside the tank. My bike ran ok until about a half tank and then it started to starve for fuel. There's a previous write up in the forum about how to fix this problem
