help please
Old Jul 12, 2016 | 06:36 PM
dgoodbmw's Avatar
dgoodbmw
Default help please
2010 ultra, removing tourpack and chrome brackets. Don't want whole 4pt docking kit. Tour pack will most likely never go back on. Looking for only the license plate brkt that would mount on (behind) factory tail light, and face upwards so the license plate light from factory would work. Also need antennae adapter so orig screw on cable will work. Anyone done this this way
Old Jul 12, 2016 | 07:13 PM
jcgribks's Avatar
jcgribks
You might go to www.shopronniesharleydavidson.com
and go to the parts micro fiche and see if any other bikes have what you need to make it work.
Old Jul 12, 2016 | 07:30 PM
dgoodbmw's Avatar
dgoodbmw
Default tried that
Thanks but, i am pretty sure that no harley has a brkt that mounts behind the tail light and points upward except the deluxe with the tombstone light.
Old Jul 13, 2016 | 06:20 AM
dinq's Avatar
dinq
The relocation kit for '14 and up has a plate that installs behind the tail light with plate above the light. Not sure if it will fit on '10 but I think the tail light assembly is the same.
PN 67900167 Bracket, License Plate
Check online. Boardtracker has it listed for $68
Might be worth a try.
Old Jul 13, 2016 | 01:00 PM
dgoodbmw's Avatar
dgoodbmw
Default bracket
Thanks to those that helped. I kept looking and found Harley part no.67900167. This pricey item goes behind the tail light and bolts on the one tail light upper bolt, it has 2 short tongues on the lower opening sides that grip the fender opening. It is included in kit 53000291a. Plenty of research on this one.
Lone Dawg
Apr 15, 2013 06:42 AM
Harleybike
Aug 10, 2012 07:52 PM
customsoftail200
Touring Parts
Feb 29, 2012 06:08 PM
skydrifter
Dec 21, 2009 08:05 PM
crashbike310
Oct 12, 2007 12:10 AM
