First build.
Old Oct 17, 2016 | 08:14 PM
CON9496's Avatar
CON9496
Stage III
Default First build.
Whats up fellas. So,I have finally decided to build my bike.
I've been in and out of shops since I was a kid, so I know my way around.
I have always had an eye for the 1942 Harley, so thats what i'm gonna roll with.
I want to put a modern power plant in, so I have a few questions...
Well I have a lot, but one I would like an answer to.
What options are available for engine conversions?
Old Oct 17, 2016 | 08:43 PM
Rocket Rider's Avatar
Rocket Rider
Welcome aboard! I'll defer to those more experienced in engines to answer your question.
Old Oct 18, 2016 | 06:38 AM
AJSHOVEL's Avatar
AJSHOVEL
So you have a '42?
Old Oct 18, 2016 | 07:02 AM
dixonk's Avatar
dixonk
Define modern power plant. With the newer motors you will need a way of hiding wiring harnesses and computers.
Old Oct 18, 2016 | 07:58 AM
0maha's Avatar
0maha
Are you building the frame? Using an aftermarket frame (eg, Paughco, etc)? Starting with a factory frame?
Do you have the resources to fab/cut/weld stuff, or is this a bolt-together project?
Old Oct 18, 2016 | 08:35 AM
corliss@bakerdrivetrain.com's Avatar
Sounds like you need an S&S Knuckle.
Old Oct 18, 2016 | 08:39 AM
Mxdad's Avatar
Mxdad
Lots of good questions for you by posters above. If you want to go with a Knucklehead as would have been in the 42 S&S makes both a 74 and 93 CI version of the knuckle. The 93 would not go in a 42 frame but I believe the 74 would.
ETA Looks like Mark at Baker beat me to the punch
Old Oct 18, 2016 | 09:15 PM
CON9496's Avatar
CON9496
Stage III
Alright, starting from the top.
AJSHOVEL. No i do not own the bike yet.
dixonk. I,m looking for the best option. Reliability is the goal.
0maha. I plan on using the factory frame. I do have access too those things at
work, other then that no. I want to keep fabrication to a minimum.
Thanks Mxdad. I'll check it out.
Thanks for the help guys.
Snarvol
Nov 7, 2010 11:17 AM
kikintires
Dec 3, 2009 11:15 PM
lmb1485
Sep 14, 2009 04:38 PM
lmb1485
Sep 14, 2009 03:15 PM
NeylorXLX
Ironhead
May 14, 2008 09:53 AM
