Rough Ride 2016 1200c
Old Nov 6, 2016 | 05:50 AM
rbert0005's Avatar
rbert0005
That is exactly why I swapped my 15 Sporty for this Duece.
Couldn't be happier.
Bob
Old Nov 6, 2016 | 07:13 AM
Mxdad's Avatar
Mxdad
Originally Posted by dastreetglide
If i install new tires with less stiff sidewalls, will it ride smoother?The michelin schorchers are extremely hard . no cushion. what do you guys think ? I dont ride fast ,not a turn burner i dont see a need for stiff sidewalls .
Less stiff sidewalls will give you a softer ride than stiff sidewalls, how much you will actually notice will vary. In my experience not enough of a difference that you really notice. IMHO the first thing I would look at is tire pressure and suspension settings. Both of those will have more of an impact on a smooth or rough ride than the tire sidewall. If tire pressure in the correct range and the suspension set for your weight do not give you the ride you are looking for then a suspension upgrade would be what I looked at next
exemexer
Nov 13, 2013 01:02 AM
superfour
Oct 6, 2013 10:45 AM
indiablue
Sep 7, 2012 10:24 AM
DENGUY
Nov 30, 2007 06:41 AM
WVULTRA
Nov 9, 2007 09:22 PM
