Sharing a battery tender
Old Jan 8, 2017 | 11:55 AM
Mchad's Avatar
Mchad
Originally Posted by ConfuciusSay
Does your Dyna have a radio or security? If not, you won't have a parasitic drain on your battery and you can leave it much longer then your Road Glide. You could do a 3 week off, 2 days on for the Dyna, with the remainder of the time on the Road Glide. YMMV
Yeah, the Low Rider S has the keyless ignition like some of the CVO's - fob present and switching run/stop to run powers up the bike, stop shuts everything down. So the security system is always looking for the fob. Seems to be putting a higher drain on the battery then my old Low Rider with a physical Off-Ign-Acc switch.
I was really asking thoughts on the week on, week off the tender. Seems like that'll be fine. Thanks all.
Old Jan 8, 2017 | 11:58 AM
Iceman24's Avatar
Iceman24
I'll take the problem off your hands...just give me one of the bikes & I'll buy the ticket to get there = problem solved.
Old Jan 8, 2017 | 12:44 PM
Donnybrook's Avatar
Donnybrook
You could remove the Dyna battery, store it in the Road Glide saddlebag, and hook up a second tender on a power strip.
Old Jan 8, 2017 | 12:55 PM
Frostbite's Avatar
Frostbite
For decades before battery tenders people would just charge the battery and disconnect it. No drain, no power loss...
Old Jan 8, 2017 | 01:37 PM
Chicago Ken's Avatar
Chicago Ken
I have battery tender quick connect pig tails attached to 3 different vehicles. I rotate the tender every week between the vehicles. Works great !
Old Jan 8, 2017 | 02:00 PM
ncdeekay's Avatar
ncdeekay
X2 on removing the batteries and keeping both on a tender in your home.
Old Jan 8, 2017 | 06:04 PM
im's Avatar
im
I had a situation once with zero access to electrical outlet.
Also had very little lighting for a solar charger.
Also had a parking issue for the bike..it was a covered area but positioning was a challenge.
I got a car battery, a voltage convertor and a battery tender.
I owed everything already except for the battery.
Bike connected to tender and tendor connected to converter and the converter connected to battery.
Carried my little system to and from as needed.
The source battery lasted about two days and was used about once or twice a month.
Tender was used to charge battery..it reads more complicated than it was.
Old Jan 8, 2017 | 06:20 PM
Bricklayer's Avatar
Bricklayer
Originally Posted by Mchad
Give me a little credit. It's not the number of outlets. I can't store both bikes in that area. It's the physical location. No room for both bikes...
Yeah, how many times do you have to explain there isnt room for both bikes
I do what some others have mentioned, week on week off.
Old Jan 8, 2017 | 06:21 PM
Uncle Larry's Avatar
Uncle Larry
You might be a bit late to the party ... He already pointed out the error of our ways regarding constraints on space.
Old Jan 8, 2017 | 06:27 PM
Bricklayer's Avatar
Bricklayer
Sounds about right for me.
