top speed limiter
Old Feb 5, 2017 | 04:30 PM
Joshus41's Avatar
Joshus41
Default top speed limiter
I tuned a breakout using the screaming eagle street interface and on the dyno the bike will only pull to 114 mph. which it reaches at 5700 rpm's in 4th gear.
I did a couple searches and can not find any threads on this which I find surprising.
any one have any insight if this is normal and if it can be disabled
thanks
Old Feb 5, 2017 | 04:37 PM
TwiZted Biker's Avatar
TwiZted Biker
Rev limiter is there for a reason and most cams quit making horsepower before reach the max anyway. Would really suck to grenade a motor just because you wanted to dick around on the dyno, seen it happen....
Old Feb 5, 2017 | 04:46 PM
Uncle Larry's Avatar
Uncle Larry
Yep ... Unless you've "reset" the rev limiter, it'll "give up at @ 5,700 rpm's ...
Old Feb 5, 2017 | 06:43 PM
nobodyknowsme's Avatar
nobodyknowsme
Why would you push your bike to 5,700 RPM's? I love my bikes too much to do that. My 6 speed Road Glide I got to 115 in 5th gear but don't think the tach was close to that. My 98 cu S&S Road King about the same speed but too busy to notice the aftermarket tach.
Old Feb 5, 2017 | 07:18 PM
RK4ME's Avatar
RK4ME
A TwinCam 88 with a conservative 95" build will do 115 mph in 5th gear, and that's rolled on in 5th gear w/no redlining.
You're doing something wrong.
Old Feb 5, 2017 | 09:00 PM
Dynamick's Avatar
Dynamick
Maybe one of your 14 other bikes will go faster?
Old Feb 5, 2017 | 10:15 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Wanna go beyond 5700rpm? Why? Stress testing for HD? It's a cruiser type engine. Root word here is "cruise."
Old Feb 6, 2017 | 05:40 AM
farmboy555's Avatar
farmboy555
Each to their own. Some people buy to ride, others keep trying to improve & one up the next guy. Just human nature
Old Feb 6, 2017 | 07:25 AM
Mxdad's Avatar
Mxdad
114 MPH Hmmmmm good to know but I have no plans to see it go there. As long as I am comfortable cruising all day and can jump up easily to 85-90 if I need it to pass on the interstate then drop back to a comfortable cruising speed around 75 I am good to go
Old Feb 6, 2017 | 08:18 AM
RHPAW's Avatar
RHPAW
My Evo has a Sreamin' Eagle ignition module (no rev limiter), among other performance things. I lifted the front end one day, and snapped the belt going into second. It revved high enough to flatten a vavle seal. It ran OK (smoked a little at idle), but we pulled the heads and fixed it at the first opportunity. It's been clocked at 117 mph (and still pulling).
(Damn kids) Yeah, I don't do that stuff anymore. But it's nice to know you can.
