Not like it would hurt anything, but in all honesty when them fans turn on its just throwing hot air at the jugs
Throwing hot air? Isn't that what happens when you're moving? Or is the air 200 degrees F? At the Harley events I've seen where the MoCo invites potential customers to sit on a running bike, they've always got a big fan blowing on it. And it's summer and 90 degrees. Throwing hot air will cool if the air being thrown is cooler than the engine. Right? And a few years ago, Hogs queued up on the highway headed toward a big motorcycle event in Milwaukee got caught in a traffic jam. Multiple engine failures.
I've had the Ward's Fans on my '13 CVO 110 for three seasons and they're still doing fine.
Not taking sides as I'm sure other fans also work well but I saw the Ward's first and went with them.
I have mine on a thermostatically controlled switch and they run all the time and usually about two minutes (a bit more in really hot weather) after I shut the engine off.
According to my information, the fans are as important at freeway speeds as they are in stop and go traffic due to the engine running at higher RPM's.
Before my (rinky-dink) digital dipstick took a dump on me, my oil temp (after exiting the freeway and stopping for fuel) usually read about 240 degrees and SYN3 is supposed to be good for temps up to 300 degrees.
I'm sure by the time my engine oil reached 300 degrees, I'd be long dead!!!
If you have $20, buy infrared laser thermometer and check head temperatures. I have one for $26. As far as I know rear head is always hotter, if I install my $3 fan, I'll install it to blow on rear head. http://www.harborfreight.com/catalog...ed+thermometer
I ride in a lot of heavy traffic. Just cant be helped if you want to get out of Metro Manila, one of the worst traffic cities. During a traffic day, EDSA can take at least 1 hour at less than 5 kph. We have had two bikes break down from the heat on our last return. I was riding my Yamaha vmax and it also overheated with a radiator, with coolant boiling over.
I had a Lenale cooling fan on my Dyna but they both crapped out (I had a replacement) after less than a year. Would have gone with a Wards but they are not around. Fans do work. But down side is that your right thigh will be roasted and I do mean 2nd degree burns. I had no choice but to tough it out on one ride and have the scars.
I did a bit of web searching trying to find some manufacturers recommendations as far as maximum cylinder head temperatures. Other than a lot of speculation by aftermarket builders and self proclaimed experts, there is very little real information available. I did find an article from Lycoming (manufacturer of air cooled aircraft engines) about cylinder head temperature sensors and recommended minimum and maximum CHT. Seems 400F is a relatively safe temperature. I'm sure the people who have installed cooling fans on their V-twins appreciate the cooler, more comfortable ride but, I doubt that it really contributes to longer engine life.
J&P Cycles has had a bike sitting all day long idling with love jugs on it at there open house for a demo , normally in the 90's with humidity in the 97% range.
I ordered the Love Jugs Might Mite more for comfort than engine protection.
Do I need them...probably not but it will go well with all the other $hit I have that I don't need.
Hey Bluraven, Use your Love Jugs for a respectful time and then revisit this comment and let us all know if your opinion stays the same. Thanks in advance. - Steve
No knock on Lenale, they are a fine company and they had the first cooling device but it is a single fan pushing hot air right through the middle of the cylinders. One doesn't have to be a science professor to realize that the result will be exactly what you described in your quote. Here's the distinction, our patented dual fan system actually keeps the engine cool (220 - 240 degrees in any riding situation) so Love Jugs are not pushing hot air from one side to the other - they provide the cooling air to prevent that uncomfortable, and engine destroying, excess heat that bedevils Harley riders. Just imagine a cooler engine and then order yourself your favorite Love Jugs to make your dream of a cooler engine come true.
Hi Dan,
Here is a short quote from a longer article by Jimmy Kay printed in several magazines and available on our love-jugs.com web site. Interestingly, Jimmy was a cynic before he took a 2000 mile trip to prove that they couldn't do what we said. Here's how he ended his article.
"And yes I do LOVE JUGS! I have had two Harley techs tell me because of the addition of the LOVE JUGS and an oil cooling system I have possibly extended the life of the most expensive part of my Harley the engine by a 50,000 miles. That is the best endorsement of a product I have ever given. LOVE JUGS are a great insurance policy and peace of mind for me. - See more at: http://love-jugs.com/two-wheel-thunder-tv-product-reviews-by-jimmy-kay-love-jugs-cool-master/#sthash.tnZUU9gp.dpuf"
