Fix a Flat - Yes or No
Old Mar 25, 2017 | 08:17 PM
skos's Avatar
skos
Default Fix a Flat - Yes or No
came out from work to find rear tire flat tonight. Got a ride home and need to fix tomorrow.
I have never used fix a Flat on a motorcycle tire. need to drive it to the dealership. Maybe a couple of miles. what do you think?
Old Mar 25, 2017 | 08:20 PM
hd4evr2008's Avatar
hd4evr2008
NO!!!!!!!! that stuff ruins the inside of your rim!
kel03's Avatar
kel03
You'll know once you put it in. Had a tire going down once, luckily near a gas station, which was a couple miles from home. Heard where the air was coming out, stuck a golf tee in the hole, made it home.
Ruined the golf tee !
Old Mar 25, 2017 | 08:27 PM
TwiZted Biker's Avatar
TwiZted Biker
This NO NO NO , seen 2 people try that crap and all it did was make a huge mess of their bikes and the tires didn't hold air.
Old Mar 25, 2017 | 08:30 PM
QC's Avatar
QC
If it's a nail, get a plug kit and some compressed air.
Old Mar 25, 2017 | 08:31 PM
FlyingSkeet's Avatar
FlyingSkeet
Can you plug it ? Or fill and ride quickly to repair shop? Fix a flat sucks A total mess to clean up but if it's your only solution you got to do what you Gotta do
Old Mar 25, 2017 | 08:40 PM
Bricklayer's Avatar
Bricklayer
If its tubeless, maybe plug it.
Old Mar 25, 2017 | 08:46 PM
Prot's Avatar
Prot
Are you running tubeless tires?
Old Mar 25, 2017 | 08:55 PM
JesseDyna's Avatar
JesseDyna
Is there damage? Posssible bad valve?
Ride-On = good
Fix a Flat = bad
BigBadAllis's Avatar
BigBadAllis
As stated above. Not a good solution. Plug it or remove it and repair or replace if possible. Even if it works, it's a future mess to deal with.
Jason
