How to tell if you have ABS
Old May 3, 2017 | 12:29 PM
r2t2k2's Avatar
r2t2k2
Originally Posted by RK4ME
Proper braking with ABS is not the same as proper braking without ABS.
OK... You piqued my curiosity. Please describe the different techniques.
Old May 3, 2017 | 12:32 PM
user 9370's Avatar
user 9370
Like this....
Old May 3, 2017 | 12:41 PM
Redoilokie's Avatar
Redoilokie
Old May 3, 2017 | 12:42 PM
baka1969's Avatar
baka1969
Originally Posted by Nomadmax
You're wrong.
Proper braking is coming to a stop in the shortest distance without causing either wheel to break traction. If you have ABS and it engages, you broke traction with one, or both, wheels. The technique is the same, ABS or non ABS.
The ONLY difference between the two is what should, or shouldn't, be done after one, or both, wheels break traction. But again, if done properly, that doesn't happen. If you truly think there is difference beyond that, I'd get some rider training.
While I won't disagree with what you said in theory, in practical terms most people don't have the (expert) skills needed to get THE absolute best from their brakes. ABS will prevent lockup in emergency stops with the vast majority of riders. Thus reducing stopping distances in all but the most expert riders.
Old May 3, 2017 | 12:50 PM
r2t2k2's Avatar
r2t2k2
Originally Posted by Ray-CA
Like this....
Touche...
Old May 3, 2017 | 12:51 PM
Dynamick's Avatar
Dynamick
Where's MikerR1 when you need him? He could have solved this controversy in 200 pages or less.
RK4ME's Avatar
RK4ME
On my non ABS bikes, I usually lead with the rear brake and apply as much pressure as needed to the front without locking either one.
On my ABS bikes, I brake the same as I would on dry pavement but release a bit earlier when entering a turn.
I've owned ABS equipped BMWs since 1995, and currently own two.
I use the ABS in my Chevy Silverado in the same way.
The use of ABS also depends on one's riding style. I like ABS because it allows me to ride faster and more and more aggressively in the rain and on gravel roads.
Old May 3, 2017 | 01:03 PM
skratch's Avatar
skratch
I think you're setting yourself up for failure. abs is not a magic pill to make you a more expert rider and can not overcome the laws of physics. yes, it will keep you from locking up your wheels in less than ideal conditions, but by doing so, it does increase the braking distance.
Old May 3, 2017 | 01:04 PM
baka1969's Avatar
baka1969
You mean the abridged version?
Old May 3, 2017 | 02:01 PM
Campy Roadie's Avatar
Campy Roadie
I don't dispute any of that. What I said was:
If you have ABS and it engages, you braked improperly. I further said, when braking is done properly, there is no difference between the technique used to achieve it, ABS or not. Engaging ABS increases stopping distance.
Then, a fellow said there was a difference technique and I said he was wrong. He still is, by the way.
