s & s super e enricher problems
Old May 25, 2017 | 05:10 PM
Mastiff107's Avatar
Mastiff107
Super E runs an enricher. There are two steps on it. In very cold I turn enricher all way on, give 3 twists of throttle, hit start button and run about 3 seconds then turn enricher off. Will flood out engine more than a few seconds, also hard on spark plugs. Only use enricher in weather below 30 degrees.
Old May 25, 2017 | 06:38 PM
raymint's Avatar
raymint
I went to the s&s web site to look for the parts and saw the enricher is a lot like on a cvo the spring is a lot shorter and the ones I saw were straight on the carb not on air cleaner, but what I think could be causing op problem is that the butterfly closes as throttle returns, unlike the cvo where the vacuum opens the slide as rpm increases. short of getting s&s to make a fast idel cam, adjusting the throttle tenchener might help to keep it runnin
DianneB
Carburetor Related
May 7, 2015 02:13 PM
ApplicationError
Exhaust System Topics
Aug 11, 2012 02:05 AM
joshoid
Jun 12, 2012 02:21 PM
stlboarder
Sep 21, 2008 01:31 PM
Spool
Dec 11, 2007 10:11 PM
