gasoline
Old Jun 3, 2017 | 05:53 AM
myglide's Avatar
myglide
You should use higher octane when your compression is higher. Octane = resistance to burn. So while your cylinder is compressing your fuel mixer it won't ignite before your spark plug ignites it. Too low of octane fuel will ignite do to compression in higher compression engines before the plug ignites it. That creates pinging and knocking. When using higher octane fuel with compression below 10 to 1 might not completely burn so it will cause your engine to build up carbon because of unburnt fuel. So the answer is NO.
Old Jun 3, 2017 | 06:05 AM
checkers's Avatar
checkers
Originally Posted by ChickinOnaChain
Mine doesn't. I put regular in mine and have for years, after I stopped putting premium in it.
Same here. My last 4 TC's have run pure gas regular 100% of the time, unless I can't get it. Runs better, idles better, smells normal and at least 1-2 mpg improvement in mpg
2005RK
2007 Ultra
2011 Heritage
2011 Road King
Old Jun 3, 2017 | 06:41 AM
shanneba's Avatar
shanneba
Originally Posted by Hey Man
The average engine will not see a significant a increase in performance difference between 89 and 91 octane but higher octane will will help with "pinging."
As compression increases so should the octane rating. Which is why NASCAR used 110 octane (but made a move to to E15 98 octane several years ago) Indy cars burn 113 octane but also using E15 fuels and Top Fuel uses nitromethane/methanol fuel.
Indy Car runs an E85 Sunoco race gas with a 99 "octane" rating-
http://www.sunocoracefuels.com/fuel/e85-r
Please note that due to the high oxygenation of E85-R, the octane values are estimated.
Note: the octane ratings for E85-R are estimates. The conventional ASTM laboratory octane tests cannot accommodate the high oxygen content of fuels like E85-R.
Old Jun 3, 2017 | 08:59 AM
Brewmany's Avatar
Brewmany
Originally Posted by checkers
Same here. My last 4 TC's have run pure gas 100% of the time, unless I can't get it. Runs better, idles better, smells normal and at least 1-2 mpg improvement in mpg
2005RK
2007 Ultra
2011 Heritage
2011 Road King
Since ethanol per volume has less BTU's than gasoline, it stands to reason that you'd see a slight change in MPG's switching between E10 and E0. Those who use E85 in their flex fuel vehicles supposedly get around 25% ish or so less miles per gallon. So the impact of 10% ethanol should be relatively minor.
My bike runs equally well on E10 as it does on E0. It's approved for up to E10, which is what most of our gas has, you have to seek out E0.
One place I fill up only offers E0 premium at their pumps, they dont' have E10 premium that I can see.
I can't tell the difference in performance, both fuels are rated 91 octane, or whatever the typical "Premium" octane rating is around here. I dont' track my MPG's very carefully, so I don't know how the E10 vs E0 thing impacts me. Doesn't appear to be too significant. I get in the Mid 40's mpg.
Old Jun 3, 2017 | 09:12 AM
ScottinAZ's Avatar
ScottinAZ
I dont have access to ethanol free, so that is a moot point for me. I did however run my last tank as premium vs "regular" and the engine is definitely quieter, leading me to believe I was getting some "Bad" things happening (pinging or knocking). I didnt see any bad signs on my plugs, IE metal deposits, signs of overheating, etc, but given our ambient heat here in PHX is over 100 degrees, I will run premium for the summer to give the engine a fair shake on not getting damaged
Old Jun 3, 2017 | 10:23 AM
Puttnik's Avatar
Puttnik
Might be time to run this again.
https://www.pure-gas.org/index.jsp?stateprov=IL
Old Jun 3, 2017 | 10:55 AM
hairymoth's Avatar
hairymoth
Wrong. Other than wasting money there is no downside to using higher a octane fuel than required. But it is true, using a higher octane gas, than required by the manufacturer, is a waste of money unless you know the brand you are using has a preferred additive package in the "premium" blend. But the best (easiest and more than sufficient) way to guarantee a good additive package is to use Top Tier rated gasoline.
Others have given the right answer: unless you have made mods to the engine that change the compression, it is best to use what the manufacturer recommends. Also, Use Top Tier rated gasoline. TopTier guarantees quality gasoline and a satisfactory additive package in all grades of the TopTier rated gasoline.
Old Jun 3, 2017 | 11:04 AM
rideflhr's Avatar
rideflhr
I
2005RK
2007 Ultra
2011 Heritage
2011 Road King
I get at least a 2mpg improvement with 93 oct real gas.
Old Jun 3, 2017 | 11:14 AM
martinj's Avatar
martinj
Originally Posted by rideflhr
I get at least a 2mpg improvement with real gas.
^^This.^^ I run ethanol free premium (91) almost all the time as it's easy to find where I live. The difference between it and 10% ethanol 91 octane is generally 2-3 mpg, and the bike clearly runs better and smoother as well. I won't run lower than 91 unless I need to fill up in a locale where 91 isn't available.
Old Jun 3, 2017 | 01:54 PM
95th 1200's Avatar
95th 1200
One thing to watch out for is E15. They recently started selling that crap by me, I'm waiting to see people complain of damaged fuel systems from unknowingly running it.
