Steering Head Zerk Fitting
Old Jun 16, 2017 | 08:50 AM
kap1's Avatar
kap1
I guess you can't get a pr of calipers in to measure it. If you can get a wrench on it and you are scrapping it anyway, why not use pliers or vice grips as a last/expedient resort?
Old Jun 16, 2017 | 09:20 AM
zman1403's Avatar
zman1403
6th Gear
That would be my last resort. I may try a right angle grease coupler first.
Thanks for your reply.
Old Jun 16, 2017 | 10:24 AM
RK4ME's Avatar
RK4ME
Have you tried a 5/16" or 6mm wrench? The type of fitting you install should depend on what your grease gun can reach.
You're right to use high temp grease, because it has a higher drop point and will stay in the steering head instead of leaking down on the front fender. The OEM Harley grease that I looked at a few years ago is way too soft.
When I lubed the neck bearings in my '04 RK, I had to fill the neck with grease, which took about half a tube. Keep an eye on the bottom of the steering neck when it becomes nearly full.
ETA: High temp automotive bearing grease is rated for use with disc brakes.
Old Jun 16, 2017 | 10:28 AM
zman1403's Avatar
zman1403
6th Gear
Thanks for the response. I will try again. My grease gun has an 18" whip. Reaching is no Problem. Getting the coupler onto the zerk fitting is the problem.
Old Jun 16, 2017 | 12:38 PM
Uncle G.'s Avatar
Uncle G.
A standard "straight" grease zerk fitting has a 5/16 hex. If it is original, it may be painted over, so a 5/16 wrench may be a tight fit.
Old Jun 16, 2017 | 12:44 PM
zman1403's Avatar
zman1403
6th Gear
Thanks I will try it again with the 5/16 wrench.
Old Jun 16, 2017 | 05:47 PM
RK4ME's Avatar
RK4ME
I replaced the original steering neck grease zerk on my '04 RK with A 90 degree type.
You can loosen the old one with any type of pliers. Most grease zerks have pipe threads, so the only way they'll bind is if they're rusted or corroded. Bring the old one with you when you get the new one, to make sure the threads match.
Old Jun 16, 2017 | 05:49 PM
dawg's Avatar
dawg
I thought a 1/4" box end wrench is what they call for, but I could be wrong.
Old Jun 16, 2017 | 06:06 PM
Jackie Paper's Avatar
Jackie Paper
If you are going to replace it, be sure you get a correct fitting. Not a clue to what Harley used in that casting. Depends on how thick it is sometimes determined design. I have a alemite and zerk book I used in engineering. Think there are more than a dozen different thread types. Some are tapered and the hole is tapped straight pipe in most cases. Then the fittings locks dry seal with no sealer.
I have a flexible line with a long thin extension on my grease gun.
I think you should get the proper tool rather than re-engineer the part. It's not like it does not exists.
Those bearing in the head come greased and are tapered rollers. In truth, it probably would last the life of the bearing. Greased once at the first call out is surely enough. It takes a ton to fill the whole cavity then. It sits on top of the lower one which is actually to only one with any load.
Old Jun 16, 2017 | 06:15 PM
NORTY FLATZ's Avatar
NORTY FLATZ
I use "Red-i" premium #2 grease. Good stuff. Tacky as heck, too.
