Steering Head Zerk Fitting
Old Jun 16, 2017 | 06:28 PM
golfblues's Avatar
golfblues
Lucas Red n Tacky comes highly recommend. Less seep/drip in hot weather then the rest.
Old Jun 16, 2017 | 06:40 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Why high temp grease?
The bearing does not even make a full 360 degree rotation and would not exceed ambient temperature.
Many high temp greases are formulated to work at 300, 400 and higher temps. They do NOT lubricate at 35 and 40 degree F very well.
Old Jun 16, 2017 | 07:45 PM
martinj's Avatar
martinj
Actually, a lot of high temp greases are formulated for temperatures from well below zero to their highest temp rating, as they often must be able to do the same job at very low startup temperatures as they do at regular working temperatures.
Old Jun 16, 2017 | 11:30 PM
RK4ME's Avatar
RK4ME
So when you leave your driveway in your disc brake equipped car or truck, the front wheel bearings aren't being lubricated very well?
Old Jun 17, 2017 | 08:43 AM
zman1403's Avatar
zman1403
6th Gear
Thanks to all for your help. After trying a right angle grease gun coupler and having it leak badly I changed the zerk fitting to a 45. This helped but I was having to maneuver the grease gun to make a good seal. So at the end of the day I installed a 90 and that works fine. The wrench was in fact a 5/16 however because of the position of the zerk the wrench would not slip on. After experimenting with two other 5/16 wrenches I got one of them to get on. After exchanging the zerk to a 90 I proceeded to pump in about a third of the tube before it started oozing out of the bottom of the steering head and then another 5-6 pumps before it came out of the top.
After doing some research on a very high heat grease I filled the head with the following WD40 grease:
https://www.wd40specialist.com/products/high-temperature-grease/
One question is did I need to see the new grease come out of the top? The new grease clearly came out of the bottom but as I pumped the old grease was squeezing out of the top. I stopped believing that the proper amount of grease was pumped in since a steady stream of the old grease was oozing out of the top.
Once again THANKS TO ALL.
Old Jun 17, 2017 | 09:14 AM
Cosmic Razorback
My point is there is nothing High Temp about neck bearings on a motorcycle.
I work in the bearing industry and have for 40years. Also sell lubricants. One of the biggest mistakes we see is that people assume that if standard grease is good, then High Temp has to be better. WRONG. They are the same only formulated to provide maximum lubricity at different operating temperatures. You need to use the correct grease for your application to assure you get the maximum lubrication year round in all temperatures. Some high temp greases will NOT lubricate in low winter temps. There are those synthetics that have a range of -30f to +400f but they are expensive and not necessary for a neck bearing. I just wanted to point out to the OP to select a grease for his application for best results.
Old Jun 17, 2017 | 11:04 AM
RK4ME's Avatar
RK4ME
High Temp grease has a higher Drop Point which is desirable for this application because a lighter grease will ooze out through the lower bearings and make a mess on the front fender. If you want to remove the bearings and hand-pack them with a lighter grease, that's fine but it's easier just to fill the steering neck with grease and "top it off" occasionally.
Old Jun 17, 2017 | 05:59 PM
Zerk's Avatar
Zerk
High temp might not be bad idea. Riding out west in low elevations , would blow on tank.
If you Google this, will come up with Napa part #.
Old Jun 17, 2017 | 07:48 PM
RK4ME's Avatar
RK4ME
Any Automotive EP chassis & bearing grease that's rated for use with disc brakes will do. I always have a couple of tubes on hand for use on my machinery and vehicles.
Old Jun 18, 2017 | 02:34 AM
georgewerr's Avatar
georgewerr
Well that would explain why every GM car iv owned needed wheel bearings replaced
