Tire pressure?
Old Jun 19, 2017 | 03:17 PM
  #61
bettingpython's Avatar
bettingpython
Originally Posted by GrandpaSpike
Well, had a local indy tell me to run 40 in front and 45 in rear. Asked him why would I do that and he said higher tire pressure will result in less friction and tires would wear better. I thanked him for the advice, but I figured the tire pressures suggested in manual were there for a reason.
I know a guy from the sportbike days who ran the exact same tires on his R1 that I ran on my 954RR He would get 6K miles out of Michelin Pilot Power 2 I was doing good to get 3500. I ran mine 36 rear 34 front for the street. He ran his at 44psi rear and 42 front. He actually rode harder than I did, but he liked to drift that bike around.
Old Jun 19, 2017 | 04:34 PM
  #62
Spy11's Avatar
Spy11
Originally Posted by bigbadpoppa
does your buddy ride? Lol. Hell no!
go with the manual like others have said. If you are an agressive rider, go down a few psi lower.
He must be quoting for a 10-speed ... bicycle!
Old Jun 20, 2017 | 03:01 AM
  #63
Bart van der Meulen's Avatar
Bart van der Meulen
Originally Posted by AJSHOVEL
It's not the only answer. Hope you never buy an old bike and try to run what the "manual" says.
Oh yes, manuals are providing information and are based on 'genuine parts'. As long as you use genuine parts I follow the manual. And when I apply non-genuine parts' I use the manual as a basic. Or otherwise the guidelines of the manufacturer of the non-genuine parts. I am a qualified engineer myself and if there is one thing I learned in my professional life, this is:
-if you don't are sure about technical things and the manuals don't provide you with the required information: direct yourself to the manufacturer of the parts concerned.
100% guarantee that you get more reliable and usefull information than turning yourself to a website, full of amateurs and 'Johnny Knows Betters".
Old Jun 20, 2017 | 08:16 AM
  #64
AJSHOVEL's Avatar
AJSHOVEL
Thanks for expanding on that. Point being, the manual can be a good starting point. It's not the be all, end all.
Old Jun 20, 2017 | 08:25 AM
  #65
NORTY FLATZ's Avatar
NORTY FLATZ
OP~ you need a new "buddy."
Old Jun 20, 2017 | 01:15 PM
  #66
SPRINGER's Avatar
SPRINGER
My 2 cents again. I feel that no matter what tire/tire pressure a person decides to use. No matter what bike/car a person decides to ride/drive, I've found that the best way to get the most out of a set of tires is to keep an eye on the wear pattern of that tire. Once a person has done that, then they can have a better idea of where their sweet spot is on the tire pressure issue.
Old Jun 20, 2017 | 02:28 PM
  #67
bikerlaw's Avatar
bikerlaw
Here's something that I think very few think about. That's tire gauges.
Many years ago, I worked for the now defunct Trak Auto. One day me and an associate took EVERY SINGLE tire gauge in the store out to the parking lot with a pad of paper. The VAST differences between the readings were staggering. And I promise you.... promise you, price didn't assure accuracy. And there could easily be a solid 3 pound reading discrepancy between the exact same brand and model. As there was close to ten pounds difference in reading between the one that read the highest and the one that read the lowest. Quite some time later I talked to a rep. from some manufacturer and asked about my findings. His response was...... and I'm not kidding:
"Actual pressure is not what's important, what matters is that all the tires are checked with the same gauge, and thus the same pressure."
I of course mentioned bikes, and that I run different pressure in the front than the rear, I run more in the back. He just said, as long as you ALWAYS use the same gauge, your fine. What a bunch of crap.
I guess the point is, if your pretty **** about tire pressure like I am, don't just assume 40psi on the gauge you got at AutoZone is actually 40psi in the tire. Cause my tests showed, that's likely not the case.
Old Jun 20, 2017 | 05:32 PM
  #68
Buelligan666's Avatar
Buelligan666
That's an oxymoron if I ever saw one...
Old Jun 20, 2017 | 08:47 PM
  #69
Mr-Mike's Avatar
Mr-Mike
I use the digital Moto-D gauge that a Michelin tire tech, at a major race event, recommended. It sure seems very accurate and repeatable to me.
What I found interesting is close a variety of cheap gauges are to actual pressures. The opposite of what you describe. I even found my bicycle pumps with built in gauges (both of them, each a different brand) to be very accurate. Even a cheap 'stick' type gauge was easily good enough.
I do believe what was stated above, I also believe there were many gauges (more than not) that were spot on or damn close.
Old Jun 20, 2017 | 09:36 PM
  #70
bikerlaw's Avatar
bikerlaw
Agreed.
The problem with what I did is that there was NO correct starting pressure. I had know idea what the REAL pressure in the tire was. So if one gauge said 27 and one said 35, I had no way to know if one was high, one was low, one was dead on and the other was garbage, or both were close. All I can attest to was there was a HUGE variance in brands. And given that every single gauge was brand new..... I don't know what to think, because repeatable, and accurate are two TOTALLY different things.
