Warm up ? Cool down
Old Aug 18, 2017 | 03:14 PM
QNman's Avatar
QNman
Idling an air-cooled engine will not allow it "cool down", I don' think. Unless you've added fans, in which case I'd wire the fans to operate after ignition shut-down.
Old Aug 19, 2017 | 07:43 AM
Bart van der Meulen's Avatar
Bart van der Meulen
Easy start, easy go. Start her up, wait 15 seconds or so till the oil reaches its pressure. Ride away without gassing or wheelies. Just normal riding away. After a minute or two you can fully load the engine. Cooling down the same, don't heat up the engine too much, end you ride as you started it and allow the bike to run idle for 10 seconds or so. Be aware that air-oil cooled bikes are not cooled enough during idling. Stop the engine and put the bike on her standard or side kick. The ticking sound you will hear after stopping and switching off the engine is the normal shrinking process of hot metal.
Old Aug 19, 2017 | 07:54 AM
DaveE's Avatar
DaveE
Originally Posted by QNman
I let it "warm up" while I back out of the garage... then I go. No special cooldown - just turn it off.
Same here.
I come from the world of air-cooled cars. Have done the same with them too.
Old Aug 19, 2017 | 09:15 AM
rkc915's Avatar
rkc915
Same as most, let it idle as I get the helmet on, raise the kickstand and go. Probably takes 20-30 seconds. I'm not getting on it right away but rather a normal steady acceleration. When I stop, I kill it after I get it in position, find neutral and lower the stand but before I drop it onto the stand. Again just a few seconds.
Old Aug 19, 2017 | 04:58 PM
Hey Man's Avatar
Hey Man
I let it warm up for about two minutes. Hitting the street and taking off on a dead cold engine is a good way to develop leaks from base, head and rocker box gaskets. Some will dispute that but I say better safe then sorry.
As far as cool down I close the petcock when I'm a couple hundred yards from the driveway, pull in the garage and shut it off.
Old Aug 22, 2017 | 10:41 AM
SgtThump's Avatar
SgtThump
Originally Posted by imjdoggie
Fire up and go.........shut right off. And brand new things I ride or drive it like I stole it. Probably not ideal but I don't hold on to stuff long enough for it to matter. Rarely needed warranties either over the years.
You described me exactly. Not saying it's right or wrong. Who knows...
Now my old carb'ed Dyna was (obviously) a whole other routine with the choke and stuff.
Old Aug 22, 2017 | 10:56 AM
elephantrider's Avatar
elephantrider
Originally Posted by ChickinOnaChain
In Texas, in the summer, it's already warmed up.
funny you mention that. took the scoot for a spin the other day. checked
the oil level, and the oil temp was right at 100 degrees
Carmo-25
Harley Davidson Videos
13
Jul 27, 2022 01:04 PM
limeyhusker
Nov 12, 2013 11:25 PM
Dr. Tiki
Apr 26, 2013 08:58 AM
jbyun
Aug 9, 2010 12:47 AM
Beercan321
Aug 16, 2009 11:04 AM
