04 Road King
Old Nov 20, 2017 | 06:26 PM
Windturbine's Avatar
Windturbine
Stage III
Default 04 Road King
Am IO for road king I went to replace the clutch cable thinking that it had snap because I had no clutch cable is fine outer inner rap are fine.Any ideas on possible causes ?
Old Nov 20, 2017 | 08:54 PM
nobodyknowsme's Avatar
nobodyknowsme
I have an 01 Road King and opened the thread hoping I could help but I can only basic english.
Old Nov 21, 2017 | 05:16 AM
stro1965's Avatar
stro1965
Have you tried adjusting the clutch? Are you sure the ***** in the "ramp" were not displaced when you were messing with the cable at the transmission end?
Old Nov 21, 2017 | 06:02 AM
nytryder's Avatar
nytryder
Is it snowing where you live?
Old Nov 21, 2017 | 08:19 AM
Windturbine
Stage III
No snow here. Inner and outer ramps replaced correct it. I had a couple of small metal like finger tabs in the housing cover when I took it off too release the clutch cable. Have not tried adjusting cable, issue occured with the clutch handle going flat. Thought cable had broke,could this be a possible clutch issue?
Old Nov 21, 2017 | 09:47 AM
RK4ME's Avatar
RK4ME
If there are "small metal like finger tabs" loose in the Primary Drive case, you should remove the cover and inspect the clutch and primary drive system. Buy a Harley Davidson Service Manual before putting a wrench to your bike.
Southern Justice
Apr 23, 2016 07:01 AM
gtrplyr
Jun 12, 2015 10:09 AM
dbrown80
Jan 20, 2012 05:29 PM
flamesnapes
Oct 5, 2008 02:55 AM
swampking
Jun 1, 2008 07:24 AM
