Key fob
Old Dec 26, 2017 | 02:03 AM
AG_65's Avatar
AG_65
Stage I
Default Key fob
When I turn ignition on it’s nit recognizing key fob and asking for the pin#, after a couple tries it usually works. Has anyone else had the same problem? And what did you do to fix it?
Old Dec 26, 2017 | 04:21 AM
sunderhill's Avatar
sunderhill
Try changing the battery in the FOB, or if you have another FOB from a different bike close by remove it
Old Dec 26, 2017 | 08:30 AM
PDB17UltraRG's Avatar
PDB17UltraRG
The symptoms you are going threw with the key fob are signs of a weak battery change the battery and it should work right. My bike came with two key fobs so i pulled out my second to test it. Good Luck
Old Dec 26, 2017 | 08:34 AM
Iceman24's Avatar
Iceman24
And...
...Sorry, someone had to do it!
Old Dec 26, 2017 | 08:52 AM
SWThomas's Avatar
SWThomas
Had the same thing happen. Thought back and my battery was about a year old. Changed battery and all is well.
Old Dec 26, 2017 | 09:51 AM
flyboyron's Avatar
flyboyron
Happened last week on my bike, I carry and extra 2032 battery for the FOB and switched them out, and it works fine now.
Old Dec 26, 2017 | 10:39 AM
critter85's Avatar
critter85
Sounds like the Fob battery!
Old Dec 26, 2017 | 10:43 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Me too. I've been carrying one for a few years...and yes, I get a new one every so often.
Old Dec 26, 2017 | 10:47 AM
sailmotion's Avatar
sailmotion
I'm not yet convinced that "it's the FOB battery" is always the answer. I've been getting the same "enter PIN" message on my Ultra. I tested the FOB battery and it tested [not under load, which evidently makes a difference] "good". The bike intermittently detects the FOB. I'm still experimenting, but I'm suspecting the culprit might actually be the bike's battery [which, BTW, is still the original (2014)].
Old Dec 26, 2017 | 10:57 AM
giacomo56's Avatar
giacomo56
As much as we want to blame the battery...it's NOT IT......(when you take the battery out and it test good )on the skinny sideof the FOB there's a small piece of foam that presses the battery agains 4 small prongs on the other side......my FOB was behaving just as you all described...i had a new battery but the signal was not being received....
THE FIX.........I slowly pried those little four prongs "up" they were flat against the battery I slowly "lifted" them off the fob and voila..I have not had an issue since....
