Sunpie led headlight
Old Mar 25, 2019 | 08:29 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Originally Posted by Softailman04
Did you have to adjust your headlight after install?
There is another recent thread about these lights ( full disclosure I have them on my 13 )
Many people said the high beam is too high and can not be adjusted down,
Mine is like that, but with the low beam as bright as it is, I never use the high beam, besides it just lights up the sky not the road.
I like mine even if the high beam is a bit off aim
Old Mar 25, 2019 | 11:24 AM
nevada72's Avatar
nevada72
Does the standard headlight trim ring work with these?
Old Mar 25, 2019 | 01:07 PM
1LargeDog's Avatar
1LargeDog
Yes. However I found that the set screw for the ring was too small for the adapter. I used one size larger but you can also use one of those spring type fender clips over the hole with the factory screw. Headlights are nice though.
Old Mar 25, 2019 | 01:31 PM
giacomo56's Avatar
giacomo56
If you can’t adjust the high beam swap the top screw with a longer one....
DellMcAlpine
Apr 21, 2014 08:09 PM
Racer78
Mar 26, 2014 09:42 AM
AmericanMuscle
Jun 3, 2012 12:33 PM
Bullbutch
May 8, 2011 07:12 AM
jim76hd
Mar 19, 2011 04:42 AM
