oil level
Old Mar 8, 2018 | 03:05 PM
moult's Avatar
moult
6th Gear
Default oil level
I have a 2017 heritage and am checking the oil level while cold and on the jiffy stand. It is exactly on the hot mark. How far down the stick should the oil be when cold? maybe half way between the fill mark and the hot mark? Not sure how much the syn3 expands and don't want to overfill. Thanks in advance for any answers
SM
Old Mar 8, 2018 | 03:11 PM
Brewmany's Avatar
Brewmany
I shoot for about half way or maybe a bit more, and also check it hot just to verify.
Overfilling can cause issues.
Old Mar 8, 2018 | 04:35 PM
SWThomas's Avatar
SWThomas
I follow what's in the owners manual.
Old Mar 8, 2018 | 07:37 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
What did the diagram in the owner's manual indicate?
Old Mar 9, 2018 | 06:18 AM
Bart van der Meulen's Avatar
Bart van der Meulen
RTFM is the answer. Read The F..ing Manual..As always the best solution.
Old Mar 9, 2018 | 06:28 AM
RK_Classic's Avatar
RK_Classic
I run my Rk 1/2 quart low, When I run full I get some blow back through the TB.
rk classic.
Old Mar 9, 2018 | 06:47 AM
blackxpress's Avatar
blackxpress
I have a 17 Heritage Softail Classic. Sometimes I check my oil when cold because I can't always remember to check it hot like the manual says. When full cold, mine reads halfway between full and add. Just to be sure I checked it that way, warmed it up and checked it hot and it was right on the full mark. Not sure if it makes any difference but I run Mobil 1 V-twin 20w50.
Old Mar 9, 2018 | 08:07 AM
ohioflhs's Avatar
ohioflhs
I never see a difference between cold and hot oil levels.
Old Mar 9, 2018 | 08:17 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I've seen a difference in my oil tank level. I have a digital dipstick and it shows a higher level when it's hot.
Old Mar 9, 2018 | 08:26 AM
RHPAW's Avatar
RHPAW
You have an oil tank. Fill it.
Bikes that have oil pans (RK, UC, etc.) can be overfilled, but it shouldn't matter on yours.
SoftailSlim_Rider
May 16, 2018 12:29 PM
gjasr1960
Oct 22, 2014 08:13 PM
Doc o
Oct 19, 2010 03:12 PM
BarryN
Oil Archive (no new posts)
May 16, 2006 02:05 PM
Jezcruzen
Aug 8, 2005 12:33 PM
