are 103 cams the same profile as the 96 tc engine,and the throttle body the same ?
Hi all ,just would like to know , as I am going to refresh a standard 07' 96 " A motor thats done 101000 miles, trouble free and still running well ,can get new 09' 103 cam's and lifters, push rod's can I use them in up coming refit of the 96a motor? that will be re bored to 103 or? , can I use the standard throttle body as well ,or what must be done ,injector's ? ,,, I prefer to keep HD engines near stock, for reliability ,been thru the never ending hot up period!!! cheers and thank's in advanced and ride well
Received 2,189 Likes
https://shop.outpostalaska.com/OEMpartfinder.htm
fish are biting today, yes sir...
I had a 96" 2010 Heritage Softail that I bought new.
I did a mild build myself, that I found to be extremely nice for power and extremely dependable. 10's of 1,000's of miles without a single issue.
Here is/was my build sheet, and what I paid for the items, which was in 2011 as I recall:
I also purchased and used to nice benefit; a TTS MasterTune software, hardware and ECM programming system. I probably would have been OK without this, but it was a lot of fun (for me) setting it up and dialing the engine in.
Also, I ran a set of V&H BSL's (which probably weren't the best power choice) and a regular Stage 1 Air Cleaner.
I bought a set of used cylinders to minimize the downtime of the bike. That way I had everything on hand before I tore anything apart.
One more thing to pay attention to is the reason I picked this particular camshaft for this engine. I could have saved a few $ by using SE255 Cams (as that is a common choice for the sort of performance I was seeking) but the dynamic compression would have almost certainly required compression releases. I also wanted the power and torque curve a few hundred RPM higher than the SE255's deliver.
- KB409C, Kieth Black Silvolite 103" Hypereutectic Piston Set, $162.76
- 26H, Andrews Camshafts, $295.00
- SE Heavy Duty Clutch Spring $25.00
- 0.030" Head Gasket, Cometic, $58.72
- Used 96” Cylinders, $25.00
- Bore 96” Cylinders for 103" Pistons, $150.00
- RA8HC Champion Spark Plugs, $2.98 ($1.49 each)
- Top end gasket set, $45.00
