Engine upgrade
Old Apr 23, 2011 | 07:37 PM
SchoonerTuner's Avatar
SchoonerTuner
Stage III
Default Engine upgrade
I have a 2001 Wide Glide, I'm trying to upgrade CI on motor without boring cases and changing cranks, What can I do to do this? Cams? Jugs and pistons? Heads? Any suggestions will be awesome thanks!
Old Apr 23, 2011 | 07:51 PM
Captain Itch's Avatar
Captain Itch
Sponsor
I think cams would give you the best easy to do bang for your buck..
__________________
www.Captain-Itch.com
Old Apr 23, 2011 | 08:26 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The quickest/easiest would be a 95" upgrade. New cylinders and pistons, Install those and the engine goes back together. Should still be able to find aftermarket kits. An extra bonus is when you add cams or upgraded heads, but then the cost goes up in relation to what you want done.
Old Apr 23, 2011 | 08:43 PM
Spanners39's Avatar
Spanners39
107" is the biggest you can go before you need to start getting into some heavy engineering.
I recently did a 103 for a customer it was a 2008 so the 50mm throttle body doesn't apply (you could use a 52mm S&S carby) but the parts list goes like this.
SE D port heads
50mm Throttle assy
103 Big Bore
Adjustable pushrods
255 Cams
V&H Short Shots
Power Commander 3
It gives 101HP and 108 Torque which is quite enough for anybody who isn't obesssed with numbers.
If doing it on a pre '06 bike I would recommend the S&S gear -driven cam conversion.
Old Apr 23, 2011 | 08:48 PM
Los11's Avatar
Los11
I would just do a S&S big bore kit some Super Stock Heads from them and some cams, lifters, etc etc.. And you will be happy
Old Apr 23, 2011 | 09:13 PM
randalwalker's Avatar
randalwalker
Just order a 120R and get it over with.
Old Apr 24, 2011 | 12:03 AM
SURFOR Chop's Avatar
SURFOR Chop
SE D port heads
50mm Throttle assy
103 Big Bore
Adjustable pushrods
255 Cams
V&H Short Shots
Power Commander 3
Since he's talking about an '01, it is starting out as an 88" motor ...
The 107" is biggest big bore kit for the 96" motor before case boring the 'spigots' or stroking it ...
For an 88" motor, the biggest you can get without case boring the 'spigots' or stroking it is a 98" big bore ...
R/
'Chop
Roddyboy
Jul 3, 2012 03:07 AM
nosillyname
Exhaust System Topics
20
Dec 13, 2010 08:16 PM
gsreimers
Apr 19, 2008 06:27 AM
goblish
38
Jan 26, 2008 04:20 PM
broke joker
May 4, 2006 11:55 AM
