Ok i had a low beam yesterday morning when I left the house and I stopped yesterday evening and killed the bike to talk on my cell phone, and when I turned the bike back on no low beam. High beam yes, low beam no. Now on the way home last night after dark about 70 MPH, I switched to low beam just for a split second to see the darkness and there was my low beam again. then this morning I had to run down town, and no low beam. So does this sound like low beam filament is broke and the twp pieces just happened to touch each other for a little bit on the way home last night? The reason I am asking is to find out if should buy another bulb, or get it checked out by my Indy first.
Could be switch or wiring too. Easy enough to pull bulb and see...good time to upgrade lighting tho. I put LED on last fall and it's the best thing I've done to my bike yet.
I'd start with the bulb first. After 11 years its probably shot or almost shot. I noticed yesterday pulling into Dairy Queen to get my salad for lunch something I had never paid attention to. During the day I ride with my high beam on. Pulling up to the plate glass I noticed that my high beam is actually the bulb in the lower portion of the headlight and the low beam is on top. I found that peculiar.
Back when headlights cost $17, I would stop someplace, buy one, and replace it in the parking lot.
Now that they cost $100, I ride home with the high beam, take it out when I get there, check first and/or replace it.
Pretty common. When you think about it, it makes sense when you consider the reflector shape behind the bulb; the upper bulb/filament will bounce more off of the top section of the reflector and throw more light down, and vice versa on the lower. My LED bulbs were both like that on my last two bikes.
I get the gist, but these were stock bulbs not LED's. I thought for a minute my switch was backwards.
Ive had this happen to me. It turned out to be a bad connection right in the headlamp plug. The contacts had lost their spring and werent gripping the bulb reliably. A bit of work with needle nose pliers fixed it.
First thing I'd suspect would be the bulb connector...had those go bad before, more than once. Then I'd branch out to the H4 bulb, if so equipped. Those are typically about fifteen bux or less on line...not sure what they cost on the street...
